Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
This is a question that comes up quite often. So, today I had some time as I wait for parts to arrive and decided to shoot a little educational media. How to change 1st gear parts in situ
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,070 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Very cool, thanks for sharing.
Dr Evil |
peteinjp |
Member ![]() ![]() Group: Members Posts: 211 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None ![]() ![]() |
Cool stuff- thanks! Is there some reason you might need to only address 1st?
Pete |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,736 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Thanks Doc!
Dr Evil |
Cool stuff- thanks! Is there some reason you might need to only address 1st? Pete 1st is the most worn out part, usually. Grinding into first, popping out of gear, are all common issues. Often, its external stuff, but even once those things are addressed the parts for first are often already shot. They are old and suffer more wear than other parts of the transmission, even in a gear box that is maintained well. So, instead of pulling the transmission and doing the work, many wish to do it with the trans in the car. Its doable, as I showed, but not overly pleasant, as I also showed. However, given the age of these cars, it is best policy to address the whole inside as it is highly likely that there are more bits needing addressed. Simply addressing 1st is just kicking the can down the road until 2nd, 3rd, etc start to fail. |
Lo-Fi Version | Time is now: 10th May 2025 - 12:14 AM |
