| BillJ |
Jan 13 2021, 09:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,357 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
So when i finish the motor going to tackle refreshing the interior. I have a more modern head unit and want to go vintage correct. What are the appropriate period options for 1975?
| BillJ |
Jan 13 2021, 09:37 AM
Bowlsby's site has the following radios as optional:
Radio Hannover(stereo - with automatic search) Blaupunkt radio - Emden with electric antenna (MW-LW-UW) Blaupunkt radio - Braunshweig What was the stock unit? |
| Thunderchief |
Jan 13 2021, 09:55 AM
Member ![]() ![]() Group: Members Posts: 199 Joined: 12-August 19 From: Pasadena, CA. Member No.: 23,365 Region Association: Southern California |
My 1974 came with a bunch of parts including a Blaupunkt Radio that I was told was from a '75 that I had tested and is for sale. PM me if you're interested.
| Mike Fitton |
Jan 13 2021, 10:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 648 Joined: 13-May 11 From: Mount Prospect, IL Member No.: 13,069 Region Association: Upper MidWest
| double-a |
Jan 13 2021, 10:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 989 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
last summer i installed a '76 model Blaupunkt Frankfurt in my '75. using a 7-pin DIN bluetooth adapter, i can pipe tunes from my phone through the deck. pretty neat!
| rfinegan |
Jan 13 2021, 10:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,230 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
I have a 75 Koln radio with auto seek that works pretty good for me. Was a high end option from what I have researched. Euro model as seen here:
Has the DIN for EQ and input for iPad /BT. works very well and good internal amp for power Attached thumbnail(s) |
| BillJ |
Jan 13 2021, 01:24 PM
last summer i installed a '76 model Blaupunkt Frankfurt in my '75. using a 7-pin DIN bluetooth adapter, i can pipe tunes from my phone through the deck. pretty neat! That is my plan as well. Nice period look but with modern function. Already have a 69'/70' Frankfurt in hand that I am about to send for reconditioning and it had the auxiliary port that can be used for Bluetooth or direct jack. Not sure i want to use that one unless you could have gotten the car with one. |
| double-a |
Jan 13 2021, 02:01 PM
if it helps anyone, this is the bluetooth adapter i purchased: https://www.ebay.com/itm/Bluetooth-music-st...lIAAOSw~hZeFd-J
| BillJ |
Jan 13 2021, 02:16 PM
if it helps anyone, this is the bluetooth adapter i purchased: https://www.ebay.com/itm/Bluetooth-music-st...lIAAOSw~hZeFd-J Extremely helpful! I got a quote of $120 to do that so this saves some dough (IMG:style_emoticons/default/beerchug.gif) |
| double-a |
Jan 13 2021, 02:24 PM
if it helps anyone, this is the bluetooth adapter i purchased: https://www.ebay.com/itm/Bluetooth-music-st...lIAAOSw~hZeFd-J Extremely helpful! I got a quote of $120 to do that so this saves some dough (IMG:style_emoticons/default/beerchug.gif) it's sold out of lithuania, arrived quickly, and the seller was responsive. there may be other options out there as well. be sure to specify to the seller whether you need the 6-pin or 7-pin variant, i believe they offer both. initial pairing took only seconds, though subsequent pairings sometimes take a moment or two to connect with my iphone. occasionally i have to hit play/pause a couple times. which is a small nit i guess, first-world problem (IMG:style_emoticons/default/biggrin.gif) |
| BillJ |
Jan 19 2021, 11:10 AM
So i worked with Thunder to acquire his period correct 1975 radio and excited to get that installed in the future! Will post some pics as things progress. Thanks everyone. Great forum with great people.
Lo-Fi Version | Time is now: 25th November 2026 - 08:31 AM |
