> Aux Blower Disassembly
friethmiller
post Aug 6 2026, 04:22 PM
Does anyone remember how to pull the fan off the Aux. motor? I've done this before but can't remember/find any pictures. I certainly don't want to break it. I've got the nut off this hamster wheel, it rotates but I can't get it to come up off the spindle. Ideas? Heat? TIA.
post Aug 7 2026, 05:45 AM
PB Blaster ? Does it have a key way wedge?
friethmiller
post Aug 7 2026, 10:03 AM
QUOTE(914Sixer @ Aug 7 2026, 06:45 AM) *
Mark, It just has two metal tabs 180 degrees for each other on the side as well as a pin looking thing just above one of them (see pic 1). I just remembered I have an early 1.7L aux fan that works. I think the motors are the same across the years. I can go that route probably but would like to get this motor open, if I can. It spins but is a little “crunchy”, if you know what I mean.
post Aug 7 2026, 11:44 AM
Is it steel on steel? A careful go with some heat might be a good place to start.
- Lo-Fi Version Time is now: 16th September 2026 - 03:21 AM
