> Drilling weep holes, Keeping the trunk rust free (ish).
post Jan 22 2026, 09:55 AM
When I got my 1972 it came with trunk rust, it was 10 years old. My 1974 has a big hole where the trunk should be. But Howard here has a trunk without any holes not designed to be there. I can remember some members here, I think Sir Andy was one talking about drilling or had drilled weep holes to let the moisture out. I’m looking for some direction on location of the holes and what size has worked best. Did you weld tubing to the hole to run it past the heat shield and muffler? Thanks
post Jan 22 2026, 10:05 AM
(IMG:style_emoticons/default/popcorn[1].gif)
is the entrance point leaky tail lights?
post Jan 22 2026, 10:14 AM
QUOTE(930cabman @ Jan 22 2026, 08:05 AM) *
On the other two probably. Though this car has no rust now, anything designed not to leak will leak. Weep holes at the bottom of an incline just makes sense.
@930cabman
Root_Werks
post Jan 22 2026, 10:23 AM
Village Idiot
Did rear trunks have weep/drain holes? I know frunk does.
post Jan 22 2026, 10:41 AM
QUOTE(Root_Werks @ Jan 22 2026, 08:23 AM) *
This is a 71 and it does not. Maybe later?
Spoke
post Jan 22 2026, 11:48 AM
Jerry
I had a leak around the rear light housings so I drilled a hole on each side and put these in to drain. I've since fixed the hole but in reality the trunk should have a way to drain water.
Drain Tube
Part#: 911-631-259-02-M260
$4.50
post Jan 22 2026, 12:24 PM
QUOTE(Spoke @ Jan 22 2026, 09:48 AM) *
Drain Tube
$4.50
Oh dude, that's the ticket. Now I just need to know where to put them. Both my other cars had no rust on the sides, it is like from the recovery point brace under the car towards the center. Maybe just buy four and evenly space them across the center section. Thanks
<ordered>
eric9144
post Jan 22 2026, 12:38 PM
A long time ago, someone actually suggested using a good bead of black silicone bathroom caulk on the tail light housings vs the funky foam seals that we're supposed to use. Seals -way- better and if you have leaks in those areas (most do), its an easy cost effective "one and done" solution.
The weep holes are a good idea! (IMG:style_emoticons/default/beerchug.gif)
post Jan 22 2026, 12:43 PM
QUOTE(eric9144 @ Jan 22 2026, 10:38 AM) *
Thanks Eric, the stock seals are lacking.
post Jan 22 2026, 01:12 PM
QUOTE(eric9144 @ Jan 22 2026, 01:38 PM) *
Be careful not to imbed the light housings in sealant, you will never be able to remove them without significant damage. Don't ask
weeps are probably a great idea, or even better, never take her out when it's raining
mlindner
post Jan 22 2026, 01:43 PM
Not sure about the trunk, but many years ago (35)years I drill extra weep holes on the lowest portion of the hell holes each side. Now 50 years old and still good. Mark
post Jan 22 2026, 02:28 PM
QUOTE(mlindner @ Jan 22 2026, 11:43 AM) *
That’s a good idea, Mark.
anderssj
post Jan 22 2026, 04:27 PM
Dog is my copilot...
Maybe put a little water in the trunk to locate the lowest point(s)/where water collects, then drill small hole in the center of the wet area(s)? (IMG:style_emoticons/default/idea.gif)
Probably want to have the car as level as possible before you start...
burton73
post Jan 22 2026, 06:40 PM
Senior member, and old dude
@ Shivers
I have seen these on my 914-6 up front. This seems to be the perfect thing for to use for the back of trunk. My rear trunk does not have any and I think that you will not be driving or storing you finished car in the rain but I could be wrong. Here in So California not much rain
Best Bob B
post Jan 23 2026, 06:56 AM
QUOTE(burton73 @ Jan 22 2026, 04:40 PM) *
@ Shivers
Best Bob B
We get a good rain every few years out here. But I have a garage & a carport. I like those, but at 4.50 I don't feel bad about having ordered the others already. Thanks Bob
post Jan 23 2026, 06:57 AM
QUOTE(anderssj @ Jan 22 2026, 02:27 PM) *
I will do this today. Thanks
5 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
1 Members: bob164
- Lo-Fi Version Time is now: 23rd January 2026 - 07:22 AM
