> Mystery Crank, ID?
trojanhorsepower
post Jan 20 2026, 07:40 PM
Anyone know how to ID this crank shaft?
post Jan 20 2026, 07:59 PM
Measure the rod journals
Dave_Darling
post Jan 21 2026, 02:18 AM
914 Idiot
And the crank throws.
Is this from a Type IV engine, or did it show up on its own?
--DD
post Jan 21 2026, 02:48 AM
Based on the rods being 2liter, this could be 71mm or more if stroked.
Doesn’t look like it’s stroked though as there should be additional material welded on either side of the crank to laterally support the rods.
Clearly welded counterweights.
But to your question; DPR were making them that way (welded) but something tells me they would brand their cranks. (IMG:style_emoticons/default/confused24.gif)
post Jan 21 2026, 06:55 AM
Check out the connecting rods and bolts ground off.
post Jan 21 2026, 07:22 AM
QUOTE(914Sixer @ Jan 21 2026, 08:55 AM) *
(IMG:style_emoticons/default/new_shocked.gif)
You guys clearly spent more time looking at that photo than I did. (IMG:style_emoticons/default/av-943.gif)
trojanhorsepower
post Jan 21 2026, 07:48 AM
Thanks all. I will check the journals tonight, if I remember correctly with out cleaning they were around 50mm. This is out of a big bore 103mm type 4 (GA) engine. I think the crank has a VW symbol on it but it is hard to tell. Definitely has welded counter weights.
trojanhorsepower
post Jan 22 2026, 05:27 PM
OK measured the journals as best as I can
Starting from the flywheel they are
59.7 49.94 49.96 59.65 49.94 49.98 x 39.65 mm
The large journal in the front still has the bearing on it because I have not gotten the cam drive gear off.
- Lo-Fi Version Time is now: 23rd January 2026 - 07:22 AM
