| 914ltd |
Jan 19 2026, 04:44 PM
Member ![]() ![]() Group: Members Posts: 245 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
The 1973 2.0 used an 8mm adjusting screw that almost never wore PN 039.109.451.
No longer available. The contact area to the valve was much larger than the other 8mm screws. I don't ever remember replacing these screws due to pitting and worn areas that the small contact 8mm screws and especially the 10mm adjusting screws failed with. These rocker assemblies will also help prevent pitting and damage to the valve stems. Changing to the "wobble foot" 911 8mm valve screw requires grinding the rocker arm, respacing the rocker assembly and resetting the geometry to correctly install. These used rocker assemblies fit all 914 and type 4 engines and will require only regular valve adjustments. Lock nuts and hardware included, $100. SOLD 3, 1.7 rebuilt Bosch injectors by Fuel Injection Corp, Tracy CA. all 3 have identical flow specs. 2 are 0 280 150 009 catalogued to Porsche 914 and one has P/N 0 280 150 007 catalogued to a 1.7 VW because it used a different hose. A replacement curved hose as well as the seals are included. $150 for the 3. Prices plus shipping and PayPal fees Attached thumbnail(s) |
| didenpx |
Jan 19 2026, 07:21 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-September 23 From: Usa Member No.: 27,556 Region Association: North East States
I’ll take the rocker assemblies. PM’d
| 914ltd |
Jan 21 2026, 02:49 PM
| didenpx |
Jan 21 2026, 06:21 PM
Brad,
Thanks for dimensions and weights. What’s best way to contact you (pm or email)? Need physical origin address and I will send you shipping label. Also need to know PayPal info. Tks! Paul |
Lo-Fi Version | Time is now: 9th February 2026 - 03:11 AM |
