| Pete_Aron |
Dec 7 2025, 02:45 PM
Newbie ![]() Group: Members Posts: 3 Joined: 5-November 25 From: Ohio Member No.: 29,079 Region Association: North East States |
Hi to everyone. I just picked up a 1970 914/4. It needs a lot of work. It came with the engine and transmission out of the car. The engine was under a tree covered with some plastic. It turns but after about a quarter turn something is stopping it inside.
The engine serial starts with EA, which I think makes it a 1972 or 1973 1.7. Definitely not original to the car. No starter, no alternator, no exhaust, no FI. The transmission was in the frunk. I'll be tearing it down in a couple of weeks. I'd like to make some mild performance improvements. Looking for reliability rather then horsepower. A budget build if that's even possible with one of these. Feel free to chime in with crank, cam, valve possibilities. Looking forward to learning from this forum and sharing my experience here. Thanks, Chris |
| brant |
Dec 7 2025, 02:58 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,112 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Nice first post
The blocks are the same. So at least you have something to build if you get the machine work done. Easy to build a bigger motor with crank rods and pistons for mild. |
| 930cabman |
Dec 7 2025, 03:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,367 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Looks great, have you explored the rockers, hell hole, any potential rust areas? Engine and trans are the easy issues |
| SO.O.C914er |
Dec 7 2025, 03:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,750 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) Welcome to our mid-engine madness!
| Pete_Aron |
Dec 7 2025, 04:13 PM
(IMG:style_emoticons/default/welcome.png) Looks great, have you explored the rockers, hell hole, any potential rust areas? Engine and trans are the easy issues I have not had a chance to look closely at the rockers or hell hole. A quick look at the hell hole shows someone did a recent rebuild of the area and didn't do a super great job. It will need attention. The PO said the jack points were "soft" which means they're probably gone. Gonna strip out the interior and try to get it into the air and get a good look in a couple of weeks. |
| Shivers |
Dec 7 2025, 05:48 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,211 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| Montreal914 |
Dec 7 2025, 08:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,975 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
(IMG:style_emoticons/default/welcome.png) and welcome to the madness.
You are at the right place for any and I mean ANY of your 914 related questions. There are extremely knowledgeable people here always willing to give great help. (IMG:style_emoticons/default/smilie_pokal.gif) Your shell seems clean, but as mentioned, you should take a close look before diving into the engine build. Of course, engine is the fun part but unfortunately, the shells can require a lot of work. Plenty of built threads that you can refer to if you get deep in the sheet metal. We are suckers for pictures (IMG:style_emoticons/default/biggrin.gif) feel free to add some more… Phone pictures are too large, you need to resize them using something like Paint to about 300k. Good luck with your project! (IMG:style_emoticons/default/driving.gif) |
| bkrantz |
Dec 7 2025, 08:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,552 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Welcome and good luck. If the engine turns reasonably easy, especially with spark plugs removed, it may be a dropped valve. Don't force it to keep turning.
| Artfrombama |
Dec 7 2025, 09:47 PM
Artfrombama ![]() ![]() Group: Members Posts: 407 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States
I’ve seen these engines stuck with just some carbon at TDC, since the motor is out it’s easy to pull the heads and check it out. |
| Cairo94507 |
Dec 8 2025, 08:30 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,522 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
(IMG:style_emoticons/default/welcome.png) Welcome Chris; that looks like a nice car to start with. You might look into a 2056 build if you end up rebuilding the complete motor. (IMG:style_emoticons/default/beerchug.gif)
| 76-914 |
Dec 8 2025, 09:13 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,828 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
| Pete_Aron |
Dec 8 2025, 03:09 PM
(IMG:style_emoticons/default/welcome.png) and welcome to the madness. You are at the right place for any and I mean ANY of your 914 related questions. There are extremely knowledgeable people here always willing to give great help. (IMG:style_emoticons/default/smilie_pokal.gif) Your shell seems clean, but as mentioned, you should take a close look before diving into the engine build. Of course, engine is the fun part but unfortunately, the shells can require a lot of work. Plenty of built threads that you can refer to if you get deep in the sheet metal. We are suckers for pictures (IMG:style_emoticons/default/biggrin.gif) feel free to add some more… Phone pictures are too large, you need to resize them using something like Paint to about 300k. Good luck with your project! (IMG:style_emoticons/default/driving.gif) Thanks Good to know about pictures. |
| krazykonrad |
Dec 8 2025, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,161 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
(IMG:style_emoticons/default/welcome.png) Welcome aboard! Address the body issues first, then the engine.
| PanelBilly |
Dec 9 2025, 08:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,937 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
(IMG:style_emoticons/default/welcome.png) I agree about working on the body first. Poke around with a screwdriver and see what you find. You picked a good car for rebuilding. Thanks to our suppliers, you can get nearly every part to fix any problem. Just comes down to spending $$$ vs value of car.
| burton73 |
Dec 9 2025, 01:47 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,925 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
You have found the right place to get answers to most of of your 914 questions. Take a look at the sandbox. I did not look there for my 1st 13 years on here. Lots of fun there. Enjoy! Best Bob B |
| worn |
Dec 9 2025, 07:08 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,515 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
(IMG:style_emoticons/default/welcome.png) I agree about working on the body first. Poke around with a screwdriver and see what you find. You picked a good car for rebuilding. Thanks to our suppliers, you can get nearly every part to fix any problem. Just comes down to spending $$$ vs value of car. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/welcome.png) I like the description including the things that didn’t come with the car. Replacing them will give you satisfaction and assurance that you have at least some confidence that those areas are taken care of. Unless of course they aren’t. The folks here represent what the internet ought to be. |
| mark04usa |
Dec 9 2025, 11:28 PM
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 361 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region
(IMG:style_emoticons/default/welcome.png) Nice early car. Does it have a Dec 69 production date?
| Tonyooc |
Dec 9 2025, 11:32 PM
1974 2.0 ![]() ![]() ![]() Group: Members Posts: 806 Joined: 6-January 18 From: Fort Mill, SC Member No.: 21,763 Region Association: South East States
(IMG:style_emoticons/default/welcome.png) Have fun with your new project.
| rick 918-S |
Dec 10 2025, 07:26 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,142 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
So far it looks like a nice car to start with (IMG:style_emoticons/default/welcome.png) Get Busy! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
| campbellcj |
Dec 11 2025, 09:24 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,679 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
(IMG:style_emoticons/default/welcome.png) You definitely are in the right place for any help, parts and moral support! I hope your journey with 914 addiction goes well and look forward to future updates.
Lo-Fi Version | Time is now: 13th December 2025 - 07:33 PM |
