> ***SOLD***FS-Weltmeister Short Shifter
BPic
post Nov 22 2025, 08:53 AM
Weltmeister Short Shifter - $175 - Zelle? free shipping lower 48 states
Attached Image Attached ImageAttached ImageAttached Image
Literati914
post Nov 22 2025, 01:01 PM
Is there actually anything different about the shift rod itself over a standard one. or is the mounting plate the only difference from a stock set up?
Ninja
post Nov 22 2025, 01:44 PM
My Weltmeister (side shifter) is longer than stock beneath the pivot point.
Mine came with a thick aluminum spacer to move the shifter plate up to keep the lever from hitting the floor pan.
This add shows the aluminum spacer...
914werke
post Nov 22 2025, 02:25 PM
QUOTE(Literati914 @ Nov 22 2025, 11:01 AM) *
Yes
Non chromed rod
the rod length above the fulcrum is shorter, below longer
Spacer to correct for dimension change in the tunnel
Exact same mounting, bolt in
NLA for the side shift
(IMG:style_emoticons/default/smile.gif)
FlacaProductions
post Nov 22 2025, 03:17 PM
This is good to go for a 74 side shifter, right?
If so...I'll take it.
PM Sent.
BPic
post Nov 22 2025, 04:09 PM
Yes it is, You may need longer bolts. I might have some that you're welcome to if I find them.
BPic
post Nov 23 2025, 05:49 AM
PENDING
post Nov 23 2025, 09:26 AM
These are hard to find. I have one in my car; we welded the stock 914 shifter arm to the new shifter assembly and it looks 100% stock in the car and does reduce the throw nicely. (IMG:style_emoticons/default/beerchug.gif)
1 Members: sixaddict
- Lo-Fi Version Time is now: 23rd November 2025 - 11:20 AM
