| sixaddict |
Nov 18 2025, 02:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 994 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
This is a silly question but I need a recommendation as to a functional spark plug socket for a six. Haven’t done this for a while, but I have two sockets, one won’t hold the plug while the other won’t release it. Turning this job into (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Thanks |
| 930cabman |
Nov 18 2025, 02:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,334 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| DennisV |
Nov 18 2025, 03:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 784 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
| sixaddict |
Nov 18 2025, 04:06 PM
Of course they have inserts…..as I said one is old and not good enough to hold the plug.
The newer one is so tight the extension pulls loose, and the socket stays behind. Like I said silly ass problem but figuring someone has a socket that works…. |
| NARP74 |
Nov 18 2025, 04:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,442 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I saw someone using a koken recently, looked and worked really well. They have several different kinds.
https://kokenusa.com/pages/spark-plug-sockets |
| sixaddict |
Nov 18 2025, 04:57 PM
Looks good
Thank you! |
| Front yard mechanic |
Nov 18 2025, 06:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,395 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Electrical tape is your friend works great for lug nuts too
| porschetub |
Nov 19 2025, 01:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,962 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Of course they have inserts…..as I said one is old and not good enough to hold the plug. The newer one is so tight the extension pulls loose, and the socket stays behind. Like I said silly ass problem but figuring someone has a socket that works…. I had the same issue ,found a seldom used one and stole the rubber from that socket that wasn't too tight on the plug ,finally found a solution ,in was a PITA ,cheers. |
| 930cabman |
Nov 19 2025, 01:33 PM
Of course they have inserts…..as I said one is old and not good enough to hold the plug. The newer one is so tight the extension pulls loose, and the socket stays behind. Like I said silly ass problem but figuring someone has a socket that works…. I had the same issue ,found a seldom used one and stole the rubber from that socket that wasn't too tight on the plug ,finally found a solution ,in was a PITA ,cheers. same issue, Koken is out of stock. I have a few plug sockets and would welcome an idiot proof tool |
| cassmcentee |
Nov 19 2025, 01:41 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California
For installing plugs in my 4 I use a short length of 1/4" fuel line inserted over the plug end. It's easy to twist till the plug is threaded and easy to pull off.
| Ninja |
Nov 19 2025, 02:26 PM
Newbie ![]() Group: Members Posts: 13 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Been wrenching daily for 4 decades... Stopped playing with "hold the plug" inserts 20 years back. Magnet for plug removal after loosening. Rubber hose for install. On EVERYTHING, not just 914s. If the threads are in proper shape, you should be able to seat the plug with the hose. If you can't the threads in the heads should be carefully wire brushed out. Shotgun cleaning kits last less than 1 year in my shop. I use a slow speed drill with them. In forward rotation it will tend to pull the debris out of the hole. In reverse it will leave the brush in the head. (IMG:style_emoticons/default/headbang.gif) I also have a 3/8 drive impact extension with a pin instead of a ball for retention. On a severe problem child, I'll use that to guarantee socket removal. |
| sixaddict |
Nov 19 2025, 05:48 PM
As usual given time …..this site always comes through! (IMG:style_emoticons/default/beerchug.gif)
| fixer34 |
Nov 19 2025, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,358 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
| rgalla9146 |
Nov 19 2025, 11:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,867 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
| jim_hoyland |
Nov 20 2025, 07:13 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,948 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Does the tape go inside ?
| bdstone914 |
Nov 20 2025, 07:51 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,190 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Electrical tape is your friend works great for lug nuts too I agree. Remove the rubber and put a couple rounds of tape on it and reinstall. Walla ! Tight as a rats ass. How do you know that a rats ass is tight? |
| bdstone914 |
Nov 20 2025, 07:56 PM
This is a BMW spark plug tool next to a 911 sparl plug tool.
It should work. It uses a plastic clip inside @sixaddict Attached thumbnail(s) |
Nov 20 2025, 10:27 PM
Electrical tape is your friend works great for lug nuts too I agree. Remove the rubber and put a couple rounds of tape on it and reinstall. Walla ! Tight as a rats ass. How do you know that a rats ass is tight? You could put your finger in it ![]() |
| frank_c |
Nov 20 2025, 10:34 PM
Newbie ![]() Group: Members Posts: 21 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Locking extensions solve the issue of the socket getting stuck on the spark plug after installing the plug. Useful for many other situations as well.
Example: https://www.amazon.com/Neiko-00295A-Extensi...TFAA/ref=sr_1_6 ![]() |
| L-Jet914 |
Nov 21 2025, 12:54 AM
Member ![]() ![]() Group: Members Posts: 367 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I second locking extensions but with a pin detent instead of the little ball as I have had spark plug sockets pop off inside a spark plug tube with the ball type locking extensions.
Lo-Fi Version | Time is now: 23rd November 2025 - 11:19 AM |
