| jmargush |
Oct 30 2025, 04:58 PM
Member ![]() ![]() Group: Members Posts: 497 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Sunday morning as I was pulling out of the driveway I noticed a flash under the dash, then i realized the gauge lights were out.
Worked on it last night and put in what is labeled as an 8 amp fuse (from Amazon) Turned lights on and after a minute or two it melts the fuse. Tried it again tonight and same thing. I was under the center console recently getting my blower motor control lever to make the fan work (turned out to be fuse in engine compartment) I don't think i disturbed anything under there. Any thoughts on what else to look for? Attached thumbnail(s) |
| porschetub |
Oct 31 2025, 01:54 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sunday morning as I was pulling out of the driveway I noticed a flash under the dash, then i realized the gauge lights were out. Worked on it last night and put in what is labeled as an 8 amp fuse (from Amazon) Turned lights on and after a minute or two it melts the fuse. Tried it again tonight and same thing. I was under the center console recently getting my blower motor control lever to make the fan work (turned out to be fuse in engine compartment) I don't think i disturbed anything under there. Any thoughts on what else to look for? When I was fitting my 6cyl gauges I had a failure with the dimmer ,when turned it had a dead short ,ended up bypassing it and no more blown fuse ,I wasn't worried as I have led lighting so no need for it anyway. I 'am not aware that you can repair the dimmer as mentioned I had no need to ,cheers |
| jmargush |
Nov 2 2025, 10:25 AM
Great I'll look into that as a possibility.
Any one knew if/ what terminals on the switch i would check to see if the dimmer failed |
| jmargush |
Nov 2 2025, 02:31 PM
Checked the headlight rheostat, didn't seem to be an issue there.
So I moved on to pulling out the gauges as i had recently been trying to get the high beam indicator working. I don't know if there a was loose or weak connection on the light or if something else got moved but i put it all back together and it seems like the issue is gone. |
Lo-Fi Version | Time is now: 3rd November 2025 - 05:17 AM |
