> oil line wtb, WTB 914-6 Case Oil discharge line
colingreene
post Sep 26 2025, 11:18 PM
Looking for the factory style 914-6 case oil discharge line that runs forward then to the drivers side of the car for the oil discharge off of the scavange pump.
one of these below
https://forums.pelicanparts.com/porsche-914...ished-part.html
Thanks
post Sep 27 2025, 05:52 AM
AA has the factory style line.
T.Rick6
post Sep 27 2025, 06:29 AM
I have one available, AA repo, never used; I believe I paid 480 for it. 400 plus shipping to your front door. (IMG:style_emoticons/default/beerchug.gif)
Todd
Cfletch
post Sep 27 2025, 07:04 PM
What is the difference between the above and this? : https://sierramadrecollection.com/products/...;pr_seq=uniform
In the above link its the same part number as the above but the photo looks like its way different.
post Sep 27 2025, 07:28 PM
QUOTE(Cfletch @ Sep 27 2025, 09:04 PM) *
PMS used to sell a part like that. Cut down 911 pipe with a fitting welded on and then plated. It’s not a factory part but can be used for 914-6 conversions.
I think their description is totally wrong.
Cfletch
post Sep 27 2025, 09:00 PM
QUOTE(mepstein @ Sep 27 2025, 06:28 PM) *
Ah okay thought I was missing something there because the PN. Are the short hoses to tank still available for this stock hardline?
sixaddict
post Sep 28 2025, 07:05 AM
Yes ….but aftermarket. AA and possibly others sell them as a “kit”.
You may also find individual pieces on evil bay.
post Sep 28 2025, 07:29 AM
The shorter hard line can make it easier to install on some non standard installations (larger engines, non stock exhaust). In my case, it didn't clearance well and I used stainless lines.
post Sep 28 2025, 10:35 AM
QUOTE(mepstein @ Sep 28 2025, 07:29 AM) *
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif)
aturboman
post Sep 28 2025, 10:54 AM
I have a spare Genuine metal line in So Cal if you did not end up finding one.
They are pricey to ship due the size. Send me a PM if interested maybe we can meet to exchange to save freight. Thanks Robert
QUOTE(colingreene @ Sep 26 2025, 10:18 PM) *
one of these below
Thanks
Steve
post Sep 28 2025, 12:12 PM
I use the short PMS line to connect to a Mocal thermostat to support a front oil cooler. That stock line was designed for a 2.0 six that doesn’t need a front oil cooler.
post Sep 28 2025, 06:06 PM
I prefer running an AN 90 backwards and have the hose go over the bell housing then kick forward right next to the feed line. It clears all heat exchanger options
post Sep 28 2025, 06:16 PM
QUOTE(mb911 @ Sep 28 2025, 08:06 PM) *
Ben made up one like he described for my next conversion car. It makes sense to me since it effectively keeps the hose away from the exhaust.
The oem hardline fits the oem 914-6 but doesn't always work as well with different engine, exhaust and engine mount combinations. Ben came up with a good alternative solution.
colingreene
post Sep 28 2025, 07:18 PM
Thanks guys,
I do have one of bens oil lines on hand, i just was curious if it would be easier to have all cohline style fittings rather than a mix of those and AN fittings.
I know full well i am being difficult.
Im also trying to figure out how the lower fitting wants to come out of the tank and into the engine bay.
post Sep 28 2025, 07:35 PM
Thanks guys,
Depends on your oil tank oem vs ben's aluminum tank and if you are doing a front cooler.
If you are doing an aftermarket setup, it's usually easier to use a/n fittings and make your own lines. If it's oem/basically copying a real 914-6 and using a Porsche steel tank, then just stick to metric.
I know full well i am being difficult. No, there are lots of ways to skin this cat.
Drill a hole at the bottom of the driver side hell hole then screw in the line once the tank is mounted.
colingreene
post Sep 28 2025, 08:22 PM
I understand that. Let me explain myself better
I know that in the factory car the lower oil fitting also seems to work as the third anchor on the tank from what I can tell, I want to see if i can replicate that for more tank security on my car.
post Sep 29 2025, 04:53 AM
QUOTE(colingreene @ Sep 28 2025, 06:22 PM) *
10 years with the 2 8mm studs for an anchor have served my 914 well. # you are reinventing the wheel for no good reason
colingreene
post Sep 29 2025, 08:32 PM
I am an engineer, its what we do.
post Sep 29 2025, 09:07 PM
QUOTE(colingreene @ Sep 29 2025, 10:32 PM) *
(IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/beerchug.gif)
colingreene
post Nov 2 2025, 05:48 PM
never did find one of these oil lines, if anyone has one it would be apreciated.
- Lo-Fi Version Time is now: 3rd November 2025 - 05:17 AM
