> 1974 2.0 Street/ Autox, Substantial price drop $21,500
914ltd
post Sep 22 2025, 05:10 PM
Porsche 914 1974 2.0 with modifications. 96,216 miles. No apparent previous crash damage, minimal rust damage. Runs and drives great.
Rebuilt engine to performance specs: Mahle European pistons and cylinders, Web 270 Cam and lifters, Balanced and lightened rotating assembly, Improved oil return control to extended sump, Rebuilt and flowed cylinder heads, Weber 44 IDF carbs with cross shaft linkage, 4 into 1 racing headers, MSD ignition. Lightened flywheel, Transaxle rebuilt with short 3rd gear, Weltmeister short shifter.
Koni double adjustable performance shock absorbers, Weltmeister 19mm adjustable front sway bar. Five bolt wheel conversion with Etolie 7X15 wheels, 914/6 front struts and brakes, Genuine 914/6 rear calipers with park brake. 21mm torsion bars, front, 160# springs rear, 914LTD chassis stiffening panels. Toyo Azenis 205/50 tires.
916 style front and rear lightweight bumpers, Fenders pulled out and smoothed for clearance, Excellent interior with custom carpet, no cracks in dash, Center console with gauges, Fittipaldi steering wheel.
Suspension pick up points are solid. The "hell hole" is great and has not been rebuilt. The rear trunk flooris excellent. Some rust in the front fenders and driver’s door.
This 914 was built in my shop 20 years ago. Care was taken to assure a dependable and attractive car was the finished product. Brad Mayeur
I'm helping with the sale of this car. The owner can no longer drive. I received the OK to drop the price. This is a great driving car and is very solid except for the aforementioned front wheelhouse corrosion.
$21,500 It's worth a lot more!
Attached Image Attached Image Attached Image Attached Image Attached Image
914ltd
post Oct 19 2025, 06:23 PM
Additional photos.
I'll get more on a Google Photos link.
914ltd
post Nov 8 2025, 09:44 AM
Just to note again, the "hell Hole" is perfect ans has not been rebuilt!
914ltd
post Nov 8 2025, 10:23 AM
914ltd
post Nov 21 2025, 08:34 PM
Take another look at this car. It is a great 914 for the money. Brad Mayeur
- Lo-Fi Version Time is now: 23rd November 2025 - 11:20 AM
