| tygaboy |
Aug 29 2025, 05:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,710 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Because I don't have enough to do, that's why.
I've fallen in love with the Group 5 car that's recently been delivered to The Red Barn where we're going to give it a bit of love and improvement. This will be covered in various "At The Red Barn" YouTube videos. This thread will cover that work as well as my attempt to build my own set of Group 5 body panels. You'll have to wait to learn what material(s) I may have selected, as well as seeing which chassis they go on. Well, and if I'll ever really do it! Here we go. Attached thumbnail(s) |
| tygaboy |
Aug 29 2025, 05:59 PM
I like most of the proportions of the existing bodywork but IMO, with some minor changes and "corrections", it could look even better.
I figured the best way to start would be to get a baseline into Fusion where I can try out various changes and get a feel for the look before committing to a final design. I'm still quite new to 3D scanning and here you can see I ended up using a combination of reflective markers and scanning spray. The spray dulls shiny surfaces that give the scanner a hard time. In all, it's pretty interesting in that it lasts only about 15 minutes before starting to disappear. It evaporates, leaving no residue! It's totally gone from the rear fender leaving only the reflective markers but you can see how it's disappearing from the front. Attached thumbnail(s) |
| tygaboy |
Aug 29 2025, 06:03 PM
And the results. Turned out pretty well.
Step 1: Complete (IMG:style_emoticons/default/aktion035.gif) Attached image(s)
| East coaster |
Aug 29 2025, 07:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,896 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
Very cool stuff….
| Cairo94507 |
Aug 30 2025, 07:11 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,498 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/beer3.gif) Love this kind of stuff. (IMG:style_emoticons/default/beerchug.gif)
| slowrodent |
Aug 30 2025, 07:19 AM
Member ![]() ![]() Group: Members Posts: 214 Joined: 29-February 20 From: Tucson/Oro Valley Member No.: 23,981 Region Association: Southwest Region
Can't wait to see where this leads.....
| Dion |
Aug 30 2025, 11:32 AM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,918 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region
Another awesome chapter from Chris!
I can’t wait. I love binge watching your episodes buddy! |
| tygaboy |
Aug 30 2025, 02:13 PM
The project scope immediately gets out of control.
A key change I want to make re: the existing available Group 5 panels is to have the bodywork not be an overlay. Essentially, make them replacement panels. Yes, that will mean cutting off all 4 quarter panels and bonding on new ones. (IMG:style_emoticons/default/blink.gif) I first need to know where the Group 5 panels differ in size/shape from the factory sheet metal. This means I need a scan of the factory panels. Well, it's a good thing I have a few 914s sitting around! So, I scanned the Ferrari car's rear quarter. The trick now is to get the Group 5 and Ferrari car scans into Fusion and used to create surfaces so I can mate the Group 5 features to the areas of the factory panel where they fit to the chassis. I mean, how hard can that be? (IMG:style_emoticons/default/huh.gif) Attached image(s)
| Shivers |
Aug 30 2025, 04:40 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,197 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Oh boy! (IMG:style_emoticons/default/w00t.gif)
| Maltese Falcon |
Aug 31 2025, 02:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,124 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
One of my '80s hang out places: Dan McLoughlin's A.I.R. fabrication + fiberglass shop, 149 Santa Anita ave/ Burbank. He designed + molded the Gr-5 body kits>>this one for John Bond jr.
Pic is from the '80s 'VW + Porsche' magazine article; AIR Porsche Bond car. 930 Turbo+trans drive-train. 934 engine would have run with flat fan tho. (IMG:style_emoticons/default/marty914.jpg) |
| Maltese Falcon |
Aug 31 2025, 03:10 AM
Clean installation, Dan was a perfectionist. His customer list was like; Steve McQueen, James Garner, Jim Hall, Richey Ginther, Whittington Bros, Paul Newman; from CanAm, RS, RSR , IROC, 935 era body panels. All of my 'glass gt parts (flat-fan car) came from Dan's shop.
| Maltese Falcon |
Aug 31 2025, 03:19 AM
| rick 918-S |
Aug 31 2025, 07:18 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,128 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
| Maltese Falcon |
Aug 31 2025, 09:42 PM
934, 935 style engine will have the horizontal (flat-fan) style air cooling/ 930 engine will run a normal 911 style vertical fan. Like the solid trans mounts Rick, those are simple T6 aluminum blocks, that are machined/ drilled and done. On the outer ends of my QuickSix mount bar (yellow stripes) I use the rear trans mount rubber-pillows from the 9146. This gives the drivetrain decent freedom to move 'Just enough. Marty |
| URY914 |
Sep 1 2025, 05:59 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 129,699 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Loved those VW+Porsche mags. I bought them all.
| Maltese Falcon |
Sep 1 2025, 08:56 AM
Loved those VW+Porsche mags. I bought them all. ...Don't know if you remember one of the editors there>> C.Van Tune; a great car guy who went on to greater TV, online (MotorTrend) automotive adventures. He passed on last year 11.16.24, rest easy Van (IMG:style_emoticons/default/driving.gif) Editor Greg Brown Photographers Les Bidrawn , Steve Reyes are all with us (IMG:style_emoticons/default/smile.gif) Now back to @tygaboy fabulous re-creation of this well loved Grüppe 5 proj ¡ (IMG:style_emoticons/default/marty914.jpg) |
| FL000 |
Sep 1 2025, 09:06 AM
Member ![]() ![]() Group: Members Posts: 478 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California
Once you get a design you like in Fusion, how do you plan to turn that into an actual part?
| Shivers |
Sep 1 2025, 10:08 AM
3D print a mold for a composite material?
| tygaboy |
Sep 1 2025, 11:43 AM
@FL000 @Shivers Scanning generates what's called a "mesh". To print, I need a solid body. To do that, the mesh gets opened in Fusion and is used as the basis to reverse engineer the shapes and work up the surfaces (or body) that'll be printed, machined, etc.
Depending on the complexity of the shape(s), it can be a ton of work, especially for a newbie like me who's learning as they go. So don't hold your breath on this. It's probably going to be a little while. |
| AZBanks |
Sep 2 2025, 05:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
I am so glad it ended up in your capable hands. A car like that needs just the right combination of insanity and perfectionism.
Lo-Fi Version | Time is now: 23rd November 2025 - 11:20 AM |
