Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,668 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Looking for a set of Pedrini rims for my Bug. Since I have factory front disc brakes, I believe I need the late hub-centric style.
Willing to pay for a set that are already restored or a set that need refinishing. Don't want anything that needs repair work. Currently running aftermarket BRM's and while okay, they don't have the quality of factory wheels. -Dan Attached thumbnail(s) ![]() |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,203 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
Is there a date code that I should look for? I have a set, maybe 5. I'll check.
Root_Werks |
@914ltd had a early set for sale here, the part number was 914.361.013.00. I don't know what a late part number would be?
Thanks for checking! -Dan |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 717 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
There is a month and year date code stamped on the rear of the Pedrini wheels showing their time of manufacture. On my car the Pedrini wheels are stamped 11/70. It is very faint and difficult to see. The stamping was done between the mounting holes on the flat surface which bolts against the hub. As a result, the date code can't be read unless the wheel is removed from the car. Unfortunately, I don't know when the change in the hub centric design was made. However, try Jeff Bowlsby's website because he probably has the info you are looking for on his site somewhere. (Bowlsby.com)
914xr75 |
Member ![]() ![]() Group: Members Posts: 184 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California ![]() |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 926 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
Late ones end with 01.
Root_Werks |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,123 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
You can have the early ones machined but that might be costly.
Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,683 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
For a bug it was common to go with after market…
We collected these a few years back… probably a bit too much for a bug. These are NOS with caps and lugs in original Porsche boxes… Attached thumbnail(s) ![]() |
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
If you dont find any late i ones let me know. I have a set of early ones and know a local machine shop that can convert them.
Last ones I had done I think were around 50 bucks a wheel to machine. |
MikeV914 |
I'm new here ... Group: Members Posts: 0 Joined: 19-May 22 From: Walnut Creek Member No.: 26,563 Region Association: Northern California ![]() ![]() |
Root_Werks |
Lo-Fi Version | Time is now: 9th May 2025 - 02:48 PM |
