thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
I have determined that the shroud on my 914-6 core is incorrect. I need the shroud that has the long ducting to the oil cooler. Anyone have the proper shroud? I also need the right side ducting next to the fan. Thanks
Attached image(s) ![]() |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,790 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
@mb911 Ben should have the engine tin, if I understood correctly what you are looking for.
EDIT: Looks like I didn't get this right... Well if you also need the perimeter tin, Ben got you covered. As for the triangular piece next to the fan, I am going through this miself. Will you have heat hexchangers or going with headers with no heat? That triangular piece would be different depending on this. |
thomasotten |
I have the surrounding tin. I just need the piece to the right of the fan, the stock piece, not a block off plate. Also, if someone has the correct 914-6 shroud.
sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Source available that makes new……my shroud was ok but I needed the light gray duct piece. He can do both …..
I think he goes by Series 9…… Nice product in my experience I will check and advise if Series 9 isn’t correct. |
sixaddict |
sixaddict |
Correction
Series 900 |
sixaddict |
thomasotten |
Yes I need the whole assembly including plate and plastic duct
sixaddict |
So I have #6 newly powder coated satin black
# 7 available new #5 I do not have. Suspect best to see if you can land the whole package. Good luck Sorry about trip on Series 900 shroud…..misunderstood your question. |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,336 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
I may have a spare #5.
I am away from my stash and will not be home until mid April. If you can’t find one remind me then and I will search my stuff. Also check withKarl Hens at Thouroughbred Motorsports up in Corey PA. He has A LOT of stuff! |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,635 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
You can just buy an addition air scoop that runs from your shroud to the cooler. Just cut a hole and rivet on. I have pictures of mine somewhere, I'll look for them. Mark
mlindner |
MasterCylinder |
Newbie ![]() Group: Members Posts: 7 Joined: 5-November 15 From: California Member No.: 19,335 Region Association: Southern California ![]() |
I have these four parts. Was told it’s a 2.2T shroud so it should be the same as a 914-6.
thomasotten |
Lo-Fi Version | Time is now: 12th March 2025 - 05:13 AM |
