1972 914 Race roller w Coldwater subaru swap pack and much more |
flyloki |
Feb 2 2025, 06:39 PM
Member Group: Members Posts: 138 Joined: 20-October 03 From: 8:00 in Boise, Idaho Member No.: 1,264 |
1972 Porsche 914 - $5500 Located in Boise ID
24 Hours of Lemons price $500 for car and $5000 for roll cage and motor swap resto parts package. 914 Subaru Race Car development roller for sale. - lost storage - available for legund team to build out and dominate.any race series Consider this a ready to assemble restomod vintage race car- build it up and go Dominate Lemons / Chump / Lucky Dog / Autocross / Track Day/ Hot Lap / or make an Ovrlandr Safari. Development started on full 914 road race chassis. Professionally built cage with 8 point tie-in to all 4 suspension towers. Ran out of storage and time so I need to find this a good home. Some (lots) assembly required. So many good parts to build Want to sell as package first but may consider parting later. Coldwater /Subaru 914 kit plus extras with 97% of parts ready to go racing. Subaru 2.5 Frankenmotor Engine Full harness rewire kit with blueprint.. 914 Speedo and Tach with adapters Race switch panel ,main breaker and Kill switch Full wiring kit including kill switch fuse panels circuit breaker etc All new fuel system with Bosch 0944 fuel pump filter fittings etc New Exedy Light flywheel and clutch. New Hydro clutch setup Suby 5mt trans from 2008 impreza Cold Water 914 Engine mount , trans hangers, Cold Water 914 cable shift w MR2 shifter, CV and axles need to be machined and adapted but have 2 sets. Full 5 Lug conversion drilled rears and 1980 911 SC Aluminum Front subframe Full Bilsteins conversion. Extra KYB rear shocks. Fuchs Cookie Cutters 2 sets 5 lug PMB Performance Rebuilt front and rear brake caliper New OEM soft brake lines New ATE 19mm brake master cylinder Tangerine Racing New SS Fuel Lines Reinforced coolant hose for exterior mount. Celica radiator installed " Gates Green Stripe" Heavy Duty Braided Coolant lines ready to run on bottom. Jetta Coolant tank 2 Rear glass windows Pedalboard and 2 clusters one with hydro master push rod installed Sparco race seat with slider mount Seat mounting dropped and reinforced for talled drivers Momo Race steering wheel 2 gas tanks Many other part$. Photos here https://photos.app.goo.gl/yJptzfSvCrDFkRi49 Attached thumbnail(s) |
carl@23 |
Feb 3 2025, 12:09 PM
I'm new here ... Group: Members Posts: 0 Joined: 2-September 24 From: New Jersey Member No.: 28,324 Region Association: North East States |
Interested in buying. Would you consider splitting up the sale? I need everything to convert my 917 to a Subaru swap. Please let me know
Carl 916.678.0014 |
technicalninja |
Feb 3 2025, 12:23 PM
Advanced Member Group: Members Posts: 2,377 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Your link to the pictures does not function.
Post a bunch of the pics to this site. Many lookers won't take the time to view links. Quick paragraph about the "Frankenmotor" might be helpful too. Looks like you have a bunch of nice stuff! GLWS! I'd be interested in some of the stuff should you end up parting out. Had you been within 250 miles of me I'd make an appointment for inspection. |
flyloki |
Feb 4 2025, 10:22 AM
Changed the photo link please let me know if you still have trouble with it.
technicalninja |
Feb 4 2025, 12:57 PM
Works fine now!
Lo-Fi Version | Time is now: 5th February 2025 - 08:10 AM |
