Throttle body, Hole in butterfly plate |
Ron914 |
Jan 18 2025, 02:10 PM
Member Group: Members Posts: 105 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California |
sixnotfour |
Jan 18 2025, 09:21 PM
914 Wizard Group: Members Posts: 10,723 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Mikey, try it,,you might like it..
https://www.youtube.com/watch?v=vYEXzx-TINc |
technicalninja |
Jan 18 2025, 09:53 PM
Advanced Member Group: Members Posts: 2,377 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I would...
That is a "bypass" hole. The reason for the hole is to allow the throttle to close enough to operate the TPS (idle position) and provide enough airflow for idle. When they first set that up it didn't have a hole, and they had trouble adjusting idle. They sized the hole specifically to improve idle adjustment. When everything is "proper" and you don't have any additional air entering past that throttle plate you will need it. If your throttle is worn out and you have excessive bypass air you won't need it. Hole or not, having additional hardware that MIGHT come off of the throttle and get into a cylinder is BAD! You are asking for a visit from the Reaper! If I wanted to close the hole, I wouldn't use a nut/bolt assembly. I'd braze it closed or something similar. I AVOID any additional hardware anywhere in the intake tract if possible. If you still have vacuum leaks (throttle shaft bushing wear can be a BIG one) opening the hole will increase your idle speed maybe to the point of being a problem. I'd leave it off and if I could not adjust to my idle, I'd tape it closed (aluminum duct tape) for test purposes. If I decided to keep the hole closed, I'd pull the throttle plate back out and permanently braze it closed. I wouldn't trust any epoxy there; too much heat cycling and vibration IMO. Edit: there is a chance the hole was drilled larger to allow the bolt clearance. If so, you WILL need a new throttle plate. Maybe someone here can provide a size (drill bit that will fit through a stock hole). I will look to my T-bodies tomorrow for a size. My stuff is basically late 1.8l L-jet and may be different from yours. There is also a chance that different years and displacements had different sized holes... |
Ron914 |
Jan 19 2025, 12:32 PM
@technicalninja
Thank you for your response . After finding the source of my vacuum leak I now have to back out the idle screw a lot when the car first starts so I believe now I might need to open that hole for now. Funny how you correct one issue and another one pops up ( I have determined I have a faulty decel valve also) . I think I will not try to close up the hole permanently until I get everything sorted out and pass my smog test . |
brant |
Jan 19 2025, 12:58 PM
914 Wizard Group: Members Posts: 11,852 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
With the butterfly installed in the TB
Can you see any light around the butterfly? 99 percent of these cars have air leaks around the plate Look in your TB and see if it has wear ridges where the butterfly clloses Most TB are worn Need new bushings and when bored slightly to be round again will need a new plate also to fit the new bore When I had my TB rebuilt the person that did the work also fabricated is new butterfly to correctly fit the remanufacturing |
Ron914 |
Jan 19 2025, 03:22 PM
With the butterfly installed in the TB Can you see any light around the butterfly? 99 percent of these cars have air leaks around the plate Look in your TB and see if it has wear ridges where the butterfly clloses Most TB are worn Need new bushings and when bored slightly to be round again will need a new plate also to fit the new bore When I had my TB rebuilt the person that did the work also fabricated is new butterfly to correctly fit the remanufacturing Interesting you asked that question. Yes I took a photo a couple of months ago . Looks like what you mentioned . Do you know who I can find that will rebuild this one for me ? |
Jan 19 2025, 03:49 PM
914 Wiring Harnesses Group: Members Posts: 8,819 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Check with Mark Kinnaman Bartlett 914
Ron914 |
Jan 19 2025, 04:03 PM
brant |
Jan 19 2025, 05:35 PM
So that is another vacuum leak. Unmetered air getting in
Ron914 |
Jan 19 2025, 07:17 PM
emerygt350 |
Jan 22 2025, 01:47 PM
Advanced Member Group: Members Posts: 2,568 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
He did mine back in April of last year.
Jan 22 2025, 02:23 PM
I'm made of metal Group: Members Posts: 4,199 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I'd love to know what the original tolerances were. Anyone have a new old stock TB tucked away somewhere?
Ron914 |
Jan 22 2025, 03:09 PM
He did mine back in April of last year. Hi Emery, I have tried all means to search for him . How did you reach him? He might just no longer providing this service, (IMG:style_emoticons/default/sad.gif) |
Jan 22 2025, 04:46 PM
emerygt350 |
Jan 22 2025, 06:28 PM
Have you sent him a PM?
Ron914 |
Jan 23 2025, 08:57 AM
Thanks You Jeff and Emery . I just sent Mark a PM.
SirAndy |
Jan 23 2025, 11:52 AM
Resident German Group: Admin Posts: 42,035 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have tried all means to search for him Y'all know we do have a member search? (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 5th February 2025 - 05:47 AM |
