> ZF LSD transmission lube, What should I use?
Driver174
post Nov 20 2024, 12:18 PM
Factory manual says Shell S1747A, but I don't see that stuff available. What lubricant do you recommend?
Replies(1 - 6)
Steve
post Nov 20 2024, 07:16 PM
QUOTE(Driver174 @ Nov 20 2024, 10:18 AM) *
I run Kendall in my 915 with LSD. It shifts better with Kendall versus Swepco, but shops love Swepco and say the internals will last longer.
https://www.pelicanparts.com/More_Info/KENL...amp;SVSVSI=0643
Geezer914
post Nov 21 2024, 05:25 AM
Geezer914
I second Kendall oil, shifts smooth.
r_towle
post Nov 21 2024, 09:03 PM
Custom Member
Interesting threads on this topic within the Ferrari community.
The Shell oil was a typical GL5 oil with an LSD additive.
It seems you can get the additive to use over the counter now.
Steve
post Nov 22 2024, 07:29 AM
QUOTE(r_towle @ Nov 21 2024, 07:03 PM) *
I had to add the additive separate with Swepco
Driver174
post Nov 22 2024, 10:28 AM
Thanks for your responses, I’ll get some Kendall ordered.
mgphoto
post Nov 22 2024, 01:25 PM
"If there is a mistake it will find me"
I use this available at most flaps.
For most american posi-rear.
Your mileage may vary.
- Lo-Fi Version Time is now: 1st April 2026 - 11:45 PM
