| zoomazoomzoom |
Nov 5 2024, 01:32 PM
Newbie ![]() Group: Members Posts: 2 Joined: 30-September 19 From: Salt Lake City, Utah Member No.: 23,509 Region Association: Rocky Mountains |
Due to circumstances beyond my control my 914 is going to have to spend our upcoming Utah Winter OUTSIDE. As you can imagine this is a bitter pill to swallow. I have done some research but am having trouble finding a suitable Outdoor All Season Car Cover for my pride and joy. I am hoping that there may be a few of you who have had experience with this and can offer some guidance. Please and thank you in advance.
| Biggles |
Nov 6 2024, 05:05 AM
Member ![]() ![]() Group: Members Posts: 205 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Due to circumstances beyond my control my 914 is going to have to spend our upcoming Utah Winter OUTSIDE. As you can imagine this is a bitter pill to swallow. I have done some research but am having trouble finding a suitable Outdoor All Season Car Cover for my pride and joy. I am hoping that there may be a few of you who have had experience with this and can offer some guidance. Please and thank you in advance. Outdoor close fitting covers, especially in your snowy climate (if you're in the hills - i've skied Snowbird and the snow fall was phenomenal !) will always be a compromise and wont really minimise rust/corrosion long term and however breathable the fabric, will always 'sweat' to some extent. Although not a perfect solution, an inflatable car bubble will be the way to go especially if you can get some air flow through it with a fan. Just give a thought too to snow build up on the cover which will cause it to sink if you dont clear it off regularly. Good luck! |
| 930cabman |
Nov 6 2024, 05:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,571 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Due to circumstances beyond my control my 914 is going to have to spend our upcoming Utah Winter OUTSIDE. As you can imagine this is a bitter pill to swallow. I have done some research but am having trouble finding a suitable Outdoor All Season Car Cover for my pride and joy. I am hoping that there may be a few of you who have had experience with this and can offer some guidance. Please and thank you in advance. You can't find a little old lady with an open garage space? I went this route for several years until i got my shop space setup |
| r_towle |
Nov 6 2024, 08:38 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Car cover, then plastic sheet cover, then waterproof car cover.
Take it all off when you get a sunny day to remove condensation. It will be fine, just a bit more time to invest in keeping moisture from building up. |
| Lockwodo |
Nov 6 2024, 10:32 AM
Member ![]() ![]() Group: Members Posts: 239 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California
Whatever car cover you decide on, monitor for moisture underneath and air out on sunny days. Park the car over concrete if possible, bare ground will become saturated when it rains and increase moisture under the car. If you can put up a car canopy to keep direct sun and rain off of the car, that will help. And, monitor for rodents, where I live they like to get up into engine compartments.
If the inflatable car bubble idea means outside moist air would be pumped into the bubble to keep it inflated, that can't be good. I've been looking for inexpensive garage space to rent for awhile. It must be out there, but like the unicorn, it's elusive. |
| Mikey914 |
Nov 6 2024, 12:11 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Use an air dryer. I've used these, but you will need to change them out every so often. I did so about every 5 weeks.
https://www.walmart.com/ip/Humydry-3-Pack-H...ectedSellerId=0 Just make sure you check on them and I hung off my steering wheel with a bucket underneath as the water will definitely promote rust due to the way it was absorbed. |
| dr914@autoatlanta.com |
Nov 6 2024, 02:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
technalon evolution three, sell them all of the time. Perfect fit, shaped like a 914!
Due to circumstances beyond my control my 914 is going to have to spend our upcoming Utah Winter OUTSIDE. As you can imagine this is a bitter pill to swallow. I have done some research but am having trouble finding a suitable Outdoor All Season Car Cover for my pride and joy. I am hoping that there may be a few of you who have had experience with this and can offer some guidance. Please and thank you in advance. |
Lo-Fi Version | Time is now: 1st April 2026 - 10:44 PM |
