Seat belt folding in guide, Driver’s Side, New Webbing |
Highland |
Sep 15 2024, 05:00 PM
Senior Member Group: Members Posts: 534 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Sep 15 2024, 05:16 PM
bdstone914 Group: Members Posts: 4,744 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Highland |
Sep 15 2024, 06:43 PM
Every time I use the belt this happens. Can’t think of how I may have incorrectly installed the seatbelt. The webbing is new and mechanism rebuilt by reputable supplier. Maybe the new belt material is too flexible. This was specifically ordered for the 914 by a well known supplier many here have used. Perhaps you’re suggesting they used the wrong material.?? |
Front yard mechanic |
Sep 15 2024, 07:42 PM
Senior Member Group: Members Posts: 1,248 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Try some starch
bkrantz |
Sep 15 2024, 07:50 PM
914 Guru Group: Members Posts: 8,206 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Could be a twist (or half twist) in the free part of the belt, so every time it retracts it carries the twist into the anchor?
Highland |
Sep 16 2024, 01:22 PM
jbyron |
Sep 18 2024, 10:58 AM
Jamie Group: Members Posts: 155 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest |
I just put in some new Corbeau seatbelts and was having the same problem. I ended up rotating the pivot point about 15 degrees counterclockwise and that took care of the problem.
87m491 |
Sep 18 2024, 01:54 PM
Member Group: Members Posts: 327 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Every time I use the belt this happens. Can’t think of how I may have incorrectly installed the seatbelt. The webbing is new and mechanism rebuilt by reputable supplier. Interestingly I just put custom color belts in my car and now this happens at least on the drivers seat. It also happens at a specific length point on the belt. Two thing help on mine. Pull the slack out more down from the guide than across your body. Pull slowly and watch for point where belt folds over and adjust pull accordingly. looking at your picture, maybe trying to get the beauty cover down closer to the belt so it physically can't roll over. |
87m491 |
Sep 18 2024, 01:57 PM
I just put in some new Corbeau seatbelts and was having the same problem. I ended up rotating the pivot point about 15 degrees counterclockwise and that took care of the problem. Similar to my fix, but the pivot point pivots how did you lock it down in the better position? |
Lo-Fi Version | Time is now: 14th January 2025 - 10:15 PM |
