Brake warning light, The quest for success continues |
PaIsa |
Sep 13 2024, 05:34 PM
Member Group: Members Posts: 86 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada |
So I am back trying to get my brake warning light to work properly. The situation before I started searching for the solution was the following:
Brake warning light was always blinking whatever the car condition. Blinked with the ignition ON. Blinked with the engine running and hand brake applied (normal). Blinked with the engine running and hand brake removed. Blinked with the engine running, hand brake removed and MC wire disconnected. So basically, blinking all the time! So I was investigating the emergency (hand) brake wiring. Remove the seats, center console, etc. Looked at the emergency brake switch and seemed to work OK. There was a contact (closed circuit) when the switch was in position where the emergency brake would be applied and no contact (open circuit) when the hand brake would be removed. Looked on the wiring for evidence of short to ground but was not able to find anything. The wire goes in the center tunnel and is accesible until the shifter where rather then following the main wiring harness and the speedo cable, it goes under and God knows where it goes!! So I was not able to follow it all the way. Now I have some disconnected wires near the brake fluid reservoir (already a thread on this trying to understand where these should go). The wires are brown-white and brown-white connected with a brown wire. The brown-white wire that is connected with the brown wire is cut. So after I reassemble the emergency brake wiring, I did some test again. Ignition ON, the brake light comes ON. Whit the engine running, no more brake light blinking. So now I tried with the cut wire (the one near the brake fluid reservoir) reconnected. Brake light blinking all the time. Disconnect the wires, no more blinking when the engine is running. I am lost. Even writing this I am not sure if I am right with the tests I did and the results I got. Anyone has any advice? I looked at the wiring diagram, but not sure!! I would like to have this working but don't want to go crazy with this!! The car is a 1972. |
Geezer914 |
Sep 13 2024, 07:59 PM
Geezer914 Group: Members Posts: 1,818 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
You need a wire diagram for your 914 depending on the year to trace the color of the wire going to the hand brake switch.
Garland |
Sep 13 2024, 09:11 PM
Restoration Fanatic Group: Members Posts: 1,400 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Ishley |
Sep 13 2024, 09:39 PM
Member Group: Members Posts: 181 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
I have a 72... and I went out to my shop and looked at my wiring diagram.
The wire that goes to the switch for the parking brake is brown/white. Any wire in the loom that has brown is a ground... the white tells you that it is a switched ground. When the parking brake is up and the switch is not depressed... the circuit is closed and the light has a ground... and therefore illuminates (when the key is on). When the brake lever is down the switch is depressed and open... and the circuit is not closed and the light goes off. The switch completes the ground through the body of the switch to the chassis... another words it should be clean around there where it mounts...etc. The two wires hanging around the brake fluid reservoir where never used for the 914 that I know of... although I did see someone on a forum somewhere....get a switch cap I believe off a VW and made it work. It was a short run of cars that had these wires. I'm not sure what your doing with those two wires... but you may be closing a circuit and changing the behavior of how it works. I put heat shrink on both of them so they wouldn't short anything...and just left them disconnected. They shouldn't be plugged together... you would be closing the circuit and that could be your issue. If you disconnect the wire (brown/white) going to the parking switch... you should be able to ground the wire to the chassis and the light with go on (with the key on of course). If it doesn't... you have a short in the wire. If you "unground" the wire... the light should go off... if it doesn't then the wire is grounding somewhere else... and you need to look for a short going upstream. Test the switch separately... using a meter set for continuity... ground to the body of the switch and the other to the connector. If all that is good... you have to make sure the switch/body is grounded well... or get a new switch. Mine works perfectly with the 72 cantilevered hand brake handle... although I had to rig up a way to make sure the switch is depressed fully.... but that a different issue then you are having. I found a wiring diagram online.... and I had it blown up... printed in color and laminated at a fedex /kinkos store. You should consider doing that so you can trace things. I hope this helps. |
Ishley |
Sep 13 2024, 09:45 PM
It's item 34 on the wiring diagram.
Sep 13 2024, 10:45 PM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's a simplified schematic of the turnsignals in the 914.
The brake warning light should only be connected to the ebrake switch and the brake warning switch on the master cylinder. The wires close to the reservoir should not be connected. |
Literati914 |
Sep 13 2024, 10:56 PM
Senior Member Group: Members Posts: 1,799 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Is there a wire plugged in at the bottom of the E-brake handle? Does it light up a test light? Do the wires at the reservoir, for that matter?
PaIsa |
Sep 14 2024, 05:04 AM
Thanks for all the answer. I knew my initial message was not really clear, but here are some more details:
Wire going to the E-brake switch: The wire has been hacked through the years. A new cable was tied in to what seem to be the original cable in the tunnel somewhere between the 2 seats. The original wire seems to be brown-yellow, although I would have thought it would be brown-white. In the image blow, we see the wire going to the E-brake switch (yellow wire running behind were should be the driver seat. The tie-in to the original wire is where there is white electrical tape. We can see on this image that the car has the wiring for the seat belts, but they are not used. As for the switch, I cleaned the switch and where it makes contact to the body for the ground before reinstalling it. Now for the stupid question: When testing this cable/switch with a test light or voltmeter, I guess that with the switch in E-brake engaged position, I should measure battery voltage or the test light should come on (with ignition ON). Is that the case. If not then it means that it is grounding or disconnected elsewhere. But since the original wire is going literally in the tunnel, it will be difficult to track it down. Hope this is a bit clearer and that it will bring some more good comments in trying to get this resolved. Again many thanks. Now for the wires near the brake fluid reservoir. I found those wires last week. Before I did not knew thay existed and the brake warning lights was always blinking. The wires were find in the way shown in the picture with one of the wire cut. Probably that before I found those, the cut wire was grounded making my brake warning light blinking. Now if I have the cut wires not grounded or connected, then my brake warnig light does not blink with the engine running (but it does light up with ignition ON). So I guess that the wires are part of this circuit, but was not able to find them or understand where they were on the wiring diagram. |
Ishley |
Sep 14 2024, 09:30 AM
If the light is always on…. Regardless of the switch…then that yellow wire is grounding somewhere. I’d pull it all back to where it’s taped.. take the tape off and check that connection. You need to check the wire for continuity to ground. Don’t worry about checking for voltage… there shouldn’t be any.
Literati914 |
Sep 14 2024, 10:49 AM
..The original wire seems to be brown-yellow, although I would have thought it would be brown-white. In the image blow, we see the wire going to the E-brake switch (yellow wire running behind were should be the driver seat. The tie-in to the original wire is where there is white electrical tape. That's interesting.. when you raised the question regarding the ebrake lever's wiring - I immediately thought 'that is a Brown/Yellow wire' (I recently went thru and installed my entire '72 harness).. then I looked at the diagram that was posted and it shows to be BR/WH. Now you say it's Brown/Yellow so I was correct on that.. wonder why the diagram chart is showing different (IMG:style_emoticons/default/idea.gif) -Anyway, there is a Diode behind the combo gauge that tie these items together (combo gauge/Seatbelt warning/Ebrake) - perhaps that diode is bad. But it's usually the simple things - I think you may be getting a flashing light because you have the seat belt warning lines disconnected. Why are they disconnected anyway? |
Sep 14 2024, 01:15 PM
914 Guru Group: Members Posts: 6,663 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Now for the stupid question: When testing this cable/switch with a test light or voltmeter, I guess that with the switch in E-brake engaged position, I should measure battery voltage or the test light should come on (with ignition ON). Is that the case. If not then it means that it is grounding or disconnected elsewhere. But since the original wire is going literally in the tunnel, it will be difficult to track it down. To answer your basic test question. When the brake switch is activated - brake lever up, the switch completes the circuit to ground, that is all. That ground is easily verified up at the back of the gauge. If it isn’t showing up there, you have wiring problems between the switch and the gauge. Please don’t take this the wrong way, my intent is to be helpful. Forget about it for the moment. Spend the time to understand the wiring diagrams (especially Spoke’s) that had been provided already. Get a digital multi meter (DMM) if you don’t already have one. Simple test lamps are not going to be very helpful to what you’re trying accomplish. Spend the time to learn how to use the DMM on simple circuits on the bench if you haven’t used one previously. YouTube is a great source for learning the basics of DMM use and electrical troubleshooting. Understand that your car has wiring that has been previously hacked up. This always makes things more challenging. Your car potentially has some wiring that is non-standard for 72’ and/or poorly documented - talking about this supposed brake fluid sensor wiring. Likewise if you have brown / yellow wiring instead of brown / white that is odd. Are you sure the yellow stripe isn’t just an aged / yellowing of what used to be a white stripe? (IMG:style_emoticons/default/confused24.gif) The brake warning lamp flasher circuit and associated flasher relay isn’t the most intuitive. Ask questions if needed to understand exactly how that circuit works. Here is a link. See post #5. http://www.914world.com/bbs2/index.php?showtopic=53850 You can do this but it is worth spending the time to learn to troubleshoot electrical issues on something easy on the bench vs trying to do it on the fly on a problem like you’re experiencing. It is almost impossible to troubleshoot effectively if you can’t predict how the circuit is supposed to work and what you should be measuring / testing. |
Sep 14 2024, 01:33 PM
So now I tried with the cut wire (the one near the brake fluid reservoir) reconnected. Brake light blinking all the time. Disconnect the wires, no more blinking when the engine is running. Brown / white is the switched ground that triggers the warning lamp. By connecting the brown wire (ground) to the brown/white wire, you are triggering the warning lamp / flasher. Clean these connections up, shrink wrap them, leave them disconnected for now, this is just further confusing your troubleshooting effort. |
PaIsa |
Sep 15 2024, 06:30 AM
Thanks for the good reply.
I have a DMM and I know how to use it for basic measurement (voltage, resistance, continuity, etc.) I have the generic wiring diagram for year 72, but there seems to have difference with my car since there are things on the wiring diagram that I don't have like the ''Seat belt warning'' under the ash tray. I will look at it a bit more and try to go deeper with my diagnostic effort. For the colors of the wire going to the E-brake switch, I will dismantle the internal of the car again likely today and take a picture of the wire to confirm the colors. Is it white that seems to have turned yellow, who knows! Now this morning I tried something since when I go the ignition ON, the brake warning light was flashing and I was earing a clicking. I got the key out of the ignition and pulled the hazard light and while the flashers were working, the brake warning light was also blinking and I was earing the same clicking which is likely the turn signal (flashers) switch. Reading Dr914 tech tips, tip #723 states: ...This loss of pressure can also be indicated with a constant clicking of the turn signal switch at your left knee under the dash... Any link here? The solution to this problem appears to be bleeding of the brakes. I will do a test today with the MC switch disconnected. I will keep you all informed. Thanks |
PaIsa |
Sep 15 2024, 06:36 AM
..The original wire seems to be brown-yellow, although I would have thought it would be brown-white. In the image blow, we see the wire going to the E-brake switch (yellow wire running behind were should be the driver seat. The tie-in to the original wire is where there is white electrical tape. That's interesting.. when you raised the question regarding the ebrake lever's wiring - I immediately thought 'that is a Brown/Yellow wire' (I recently went thru and installed my entire '72 harness).. then I looked at the diagram that was posted and it shows to be BR/WH. Now you say it's Brown/Yellow so I was correct on that.. wonder why the diagram chart is showing different (IMG:style_emoticons/default/idea.gif) -Anyway, there is a Diode behind the combo gauge that tie these items together (combo gauge/Seatbelt warning/Ebrake) - perhaps that diode is bad. But it's usually the simple things - I think you may be getting a flashing light because you have the seat belt warning lines disconnected. Why are they disconnected anyway? I will get a good picture of the wire today to clarify the colors! For the diode, I am not sure I was able to see it. Not sur what I am looking for. I will look at the wiring diagram to have a better feel of where to look for. Since I don't have a seat belt waning light (the one under the ash tray), then I guess that this is why these cables are not connected (the ones for the seat belts in the center console. |
Sep 15 2024, 07:51 AM
So at this point what is the main issue?
If I’ve read your post correctly it’s that at ignition on, engine off, no parking brake applied, the warning lamp is flashing but the flashing goes away with engine running? |
PaIsa |
Sep 15 2024, 08:36 AM
So at this point what is the main issue? If I’ve read your post correctly it’s that at ignition on, engine off, no parking brake applied, the warning lamp is flashing but the flashing goes away with engine running? Ignition ON, engine OFF: Brake light is blinking whatever the status of the E-brake Engine running: Brake light OFF whatever the status of the E-brake So my understanding is that this light should be ON when E-brake is applied or MC switch is activated. So in my case, assuming that the MC switch is in open condition, then when E-brake is applied the light should be ON. Anyway for now I will put that on ice and wait for the period when the car will be stored to work further on this. |
PaIsa |
Sep 15 2024, 08:42 AM
..The original wire seems to be brown-yellow, although I would have thought it would be brown-white. In the image blow, we see the wire going to the E-brake switch (yellow wire running behind were should be the driver seat. The tie-in to the original wire is where there is white electrical tape. That's interesting.. when you raised the question regarding the ebrake lever's wiring - I immediately thought 'that is a Brown/Yellow wire' (I recently went thru and installed my entire '72 harness).. then I looked at the diagram that was posted and it shows to be BR/WH. Now you say it's Brown/Yellow so I was correct on that.. wonder why the diagram chart is showing different (IMG:style_emoticons/default/idea.gif) -Anyway, there is a Diode behind the combo gauge that tie these items together (combo gauge/Seatbelt warning/Ebrake) - perhaps that diode is bad. But it's usually the simple things - I think you may be getting a flashing light because you have the seat belt warning lines disconnected. Why are they disconnected anyway? Just confirm the wire color: it is Brown-Yellow (see photo). I am pretty sure it is the original wire. |
Sep 15 2024, 10:16 AM
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/headbang.gif)
Oh man, that is a crazy set of symptoms. I’m going to have to do some thinking on that one. Looking at how that harness is taped up, someone has defiantly mucked with it. What build month is your car on the door post label? Happy to help you step by step when the time comes. (IMG:style_emoticons/default/beerchug.gif) |
Sep 15 2024, 10:20 AM
That's interesting.. when you raised the question regarding the ebrake lever's wiring - I immediately thought 'that is a Brown/Yellow wire' (I recently went thru and installed my entire '72 harness).. @Literati914 So was your harness brown/yellow all the way up to the back of the gauge and also down at the master cylinder switch? |
Literati914 |
Sep 15 2024, 12:35 PM
@Literati914 So was your harness brown/yellow all the way up to the back of the gauge and also down at the master cylinder switch? I thought that was the case.. but I just checked. The wire going to my Ebrake handle is BR/YL (like the original poster verified his was originally)..while the wires going to my brake warning switch @ m/c is BR/WH (besides the BR ground wire). Just a mistake on this particular diagram? I don't know, probably (IMG:style_emoticons/default/confused24.gif) . My harness is original, build date 05/72 I believe. @PaIsa - I asked earlier, why the seat belt warning lines are disconnected... I understand it's popular because of the annoying buzzer but from memory I think it needs a particular "loop" of wire to bridge two points on it's relay (that's under the passenger's seat). I'm suggesting that if it's not correctly done it may cause a flashing light warning for the situation. Have you looked at the wiring under the passenger seat? I'm just guessing here.. but I'd check if you haven't already. |
Lo-Fi Version | Time is now: 14th January 2025 - 10:41 PM |
