SWH |
Newbie ![]() Group: Members Posts: 8 Joined: 27-April 24 From: Arizona Member No.: 28,084 Region Association: Southwest Region ![]() |
I replaced side shift seal and all shifter bushings. I now do not have all gears, it only has a “H” pattern. Any suggestions on how to correct?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,787 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I replaced side shift seal and all shifter bushings. I now do not have all gears, it only has a “H” pattern. Any suggestions on how to correct? Are you adjusting at the shifter base but can't get the adjustment right? (IMG:style_emoticons/default/idea.gif) |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,033 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
maybe you do not have the set screws seated to where the shift rod is off. After you check that carefully then adjust the shifter. If it shifted well before it should do the same however
I replaced side shift seal and all shifter bushings. I now do not have all gears, it only has a “H” pattern. Any suggestions on how to correct? |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,986 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
I am going with George's answer. (IMG:style_emoticons/default/beerchug.gif)
SWH |
Both set screws were in correct location. What adjustment is possible at shifter base?
SirAndy |
What adjustment is possible at shifter base? All the adjustments. (IMG:style_emoticons/default/smile.gif) That's where you adjust the shifter after replacing bushings etc. (IMG:style_emoticons/default/popcorn[1].gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,184 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Go to members. Click on filters. Contains ‘Evil’ in member name. Click on member. Review 30+ pages link in signature.
Index/mark the current linkage connection points with a fine tip Sharpie so you know your starting point. Did you take the whole linkage apart? Did you address the bottom side of the shifter? |
SWH |
Shift linkage disassembled including side linkage into trans. Needed seals replaced due to leak. Motor is currently out now for rebuild. Will recheck again after installation. Will also check recommended link. Thanks
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,025 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Shift linkage disassembled including side linkage into trans. Needed seals replaced due to leak. Motor is currently out now for rebuild. Will recheck again after installation. Will also check recommended link. Thanks Ill save ya a search. Link below in my sig (IMG:style_emoticons/default/smile.gif) |
technicalninja |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
Hands down the best Porsche tranny guy and info out there. The Dr. is a GOD! |
Lo-Fi Version | Time is now: 7th September 2024 - 08:39 PM |
