Lof8 |
Newbie ![]() Group: Members Posts: 19 Joined: 29-December 23 From: Bradenton, FL Member No.: 27,823 Region Association: South East States ![]() |
I had read about the cure-all bushing to fix the steering column play. I ordered myself one and once I began digging into it and watching some youtube videos, it seems the bushing is for later cars and doesn't work in the early cars. Does repairing this play in an early car require total disassembly? Thanks for any guidance.
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,644 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I had read about the cure-all bushing to fix the steering column play. I ordered myself one and once I began digging into it and watching some youtube videos, it seems the bushing is for later cars and doesn't work in the early cars. Does repairing this play in an early car require total disassembly? Thanks for any guidance. I think the replacement plastic bushing will fit all years. Do you have the metal crush sleeve in your column? |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,033 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
is the column chunk tightly bolted against the body?
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,980 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Another option
Attached thumbnail(s) ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,986 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Is the spring installed under the steering wheel? I had a wiggle in my steering wheel that bugged me. Upon removal of the steering wheel, the large spring that goes on before the wheel is installed was missing. Installed a spring (thanks Greg T.) and it is nice now. (IMG:style_emoticons/default/beerchug.gif)
Lof8 |
is the column chunk tightly bolted against the body? yeah, the column bolts are tight. This is the bushing I purchased. It does not appear there's any way to install this thing in my steering column assembly. (IMG:http://www.914world.com/bbs2/uploads_offsite/s3.us-east-2.amazonaws.com-27823-1721994767.1.jpg) |
Your part is for 72-76.
Lof8 |
Thats what i've gathered. It won't work on my '70. Is there an easy fix for my car? Or whats inviolved to eliminate the steering column slop/wiggle?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,787 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Thats what i've gathered. It won't work on my '70. Is there an easy fix for my car? Or whats inviolved to eliminate the steering column slop/wiggle? Yes, there is a corrugated version of this that works for early cars. I haven't seen one of those in years though. Maybe a 911 part? (IMG:style_emoticons/default/idea.gif) |
SirAndy |
Thats what i've gathered. It won't work on my '70. Is there an easy fix for my car? Or whats inviolved to eliminate the steering column slop/wiggle? Yes, there is a corrugated version of this that works for early cars. I haven't seen one of those in years though. Maybe a 911 part? (IMG:style_emoticons/default/idea.gif) Found an image. Might actually be a VW part for Bugs and Karmann Ghia (IMG:style_emoticons/default/idea.gif) Attached image(s) ![]() |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,419 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
On 50 year old cars there is rarely an easy fix.
It isn’t that difficult to remove the column and replace bearings FWIW. |
Early 70-71 cars used the VW Type 3 variation for the steering column.72-74 came from VW Bug. 75-76 came from Early VW Rabbit.
Lo-Fi Version | Time is now: 7th September 2024 - 08:22 PM |
