Fresh Air Box Vent Block Off, Want to permanently remove air box |
Nor.Cal.914 |
Apr 26 2024, 09:53 AM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
As the title states, I'm in the process of deleting all of my HVAC components and the last thing I have left is the removal of the fresh air box/blower motor housing. I have found the block off plates needed for the 6 vent and hose holes, but I'm having trouble finding someone who makes something to seal off the fresh air vent for the air box. I tried searching here, went through about 10 pages with no luck of finding anything other than how to remove and rebuild the box.
Does anyone know of someone who makes a block off plate for the vent on the cowl? I guess worst case scenario would be to just make something from sheet metal, but would be nice if there is a kit already made with the seal, hardware, etc. Thank you! |
DRPHIL914 |
Apr 26 2024, 11:27 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i have to ask why?? you probably are not finding anything about it because i dont think anyone does that. i mean if you are racing the car not sure this is a reason but if you have it out anywhere that you get rain you will need that rain to go somewhere, i guess you could bolt a plate over the opening (IMG:style_emoticons/default/confused24.gif) i would not advise it. I am glad i restored my box with new seals and grate and motor etc its nice to have the ability to move air for defrost etc.
you might reconsider that, parts for fixing the fresh air box are readily available. Phil. |
Apr 26 2024, 11:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I just used sheet plastic and super glue to make a blockoff plate for it.
I wanted to block it off while I was working on the AC unit. The AC is not finished and the blockoff plate is still there. |
Nor.Cal.914 |
Apr 26 2024, 12:29 PM
i have to ask why?? you probably are not finding anything about it because i dont think anyone does that. i mean if you are racing the car not sure this is a reason but if you have it out anywhere that you get rain you will need that rain to go somewhere, i guess you could bolt a plate over the opening (IMG:style_emoticons/default/confused24.gif) i would not advise it. I am glad i restored my box with new seals and grate and motor etc its nice to have the ability to move air for defrost etc. you might reconsider that, parts for fixing the fresh air box are readily available. Phil. I have so many leaks in this car that I won't ever be driving it in the rain (IMG:style_emoticons/default/lol-2.gif) I never found the HVAC system very useful for me (other than heat when I had heat exchangers). Blowing ambient air into the car to try and "cool off" didn't help much on hot days either so for me it's windows down and top off! I'll probably end up putting a plate with a drain tube on it so that water doesn't puddle up in the opening whenever I wash it. Thank you for the input! (IMG:style_emoticons/default/beerchug.gif) |
Nor.Cal.914 |
Apr 26 2024, 12:30 PM
I just used sheet plastic and super glue to make a blockoff plate for it. I wanted to block it off while I was working on the AC unit. The AC is not finished and the blockoff plate is still there. Seems like I will be doing something similar, but a more permanent fix since I don't intend on putting the box back in at any point. Thank you! (IMG:style_emoticons/default/beerchug.gif) |
burton73 |
Apr 26 2024, 01:05 PM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I just used sheet plastic and super glue to make a blockoff plate for it. I wanted to block it off while I was working on the AC unit. The AC is not finished and the blockoff plate is still there. Seems like I will be doing something similar, but a more permanent fix since I don't intend on putting the box back in at any point. Thank you! (IMG:style_emoticons/default/beerchug.gif) If you have to do it, my suggestion is to use ABS sheet plastic and ABS glue as it works well, better than crazy glue on plastic. You can get sheet ABS from Amazon as well as the WELDON ABS glue. You can heat with a high temp heat gun and form bends Best Bob B |
Nor.Cal.914 |
Apr 26 2024, 03:50 PM
I just used sheet plastic and super glue to make a blockoff plate for it. I wanted to block it off while I was working on the AC unit. The AC is not finished and the blockoff plate is still there. Seems like I will be doing something similar, but a more permanent fix since I don't intend on putting the box back in at any point. Thank you! (IMG:style_emoticons/default/beerchug.gif) If you have to do it, my suggestion is to use ABS sheet plastic and ABS glue as it works well, better than crazy glue on plastic. You can get sheet ABS from Amazon as well as the WELDON ABS glue. You can heat with a high temp heat gun and form bends Best Bob B That sounds like a much better option than sheet metal! Will be much easier to make it out of one piece that way I would think. Thank you so much! (IMG:style_emoticons/default/beerchug.gif) -Christopher |
76-914 |
Apr 26 2024, 04:25 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
On my '73 conversion w/ AC/Heat I gutted the box leaving it in place with drain tubes to remove/divert any water I happen to encounter. (IMG:style_emoticons/default/beerchug.gif)
sixnotfour |
Apr 26 2024, 07:20 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached image(s) |
Apr 26 2024, 09:41 PM
I just used sheet plastic and super glue to make a blockoff plate for it. I wanted to block it off while I was working on the AC unit. The AC is not finished and the blockoff plate is still there. Seems like I will be doing something similar, but a more permanent fix since I don't intend on putting the box back in at any point. Thank you! (IMG:style_emoticons/default/beerchug.gif) If you have to do it, my suggestion is to use ABS sheet plastic and ABS glue as it works well, better than crazy glue on plastic. You can get sheet ABS from Amazon as well as the WELDON ABS glue. You can heat with a high temp heat gun and form bends Best Bob B Bob, I know for a fact that Volkswagen built lots of AC units using super glue and plastic. The Vanagon AC unit sold in the 80s was assembled completely with super glue. My father worked on the design team for it and he brought home lots of samples of super glue for us. Plus accelerator for it. Spray the accelerator on one part, and put the glue on the other. The minute they touch, it is dry. Gets hot doing so, and you can hear it crackle. Clay |
mlindner |
Apr 27 2024, 05:10 AM
Senior Member Group: Members Posts: 1,518 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I have mine closed off. Bent sheet metal, some 1/4 inch foam tape to seal and a drain hole with tubing to the underside. Not sure why I did this, car is not driven in the rain. Best, Mark
iankarr |
Apr 27 2024, 09:54 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
It's all fine and fun until the windshield gets fogged up.
burton73 |
Apr 27 2024, 12:16 PM
I just used sheet plastic and super glue to make a blockoff plate for it. I wanted to block it off while I was working on the AC unit. The AC is not finished and the blockoff plate is still there. Seems like I will be doing something similar, but a more permanent fix since I don't intend on putting the box back in at any point. Thank you! (IMG:style_emoticons/default/beerchug.gif) If you have to do it, my suggestion is to use ABS sheet plastic and ABS glue as it works well, better than crazy glue on plastic. You can get sheet ABS from Amazon as well as the WELDON ABS glue. You can heat with a high temp heat gun and form bends Best Bob B Bob, I know for a fact that Volkswagen built lots of AC units using super glue and plastic. The Vanagon AC unit sold in the 80s was assembled completely with super glue. My father worked on the design team for it and he brought home lots of samples of super glue for us. Plus accelerator for it. Spray the accelerator on one part, and put the glue on the other. The minute they touch, it is dry. Gets hot doing so, and you can hear it crackle. Clay Hi Clay, I am not saying that Superglue is not good if the job calls for it. Note the picture of some of my jobs in the early 90s. The Ship that had so many parts and the cryogenic Tanks job where built with a Superglue and I have used the kicker spray from the early 80s on. By the way you can use baking soda as a gap filler, and you get the same sound. When it holds it is great but with ABS plastic, and ABS pipe glue the joining surfaces melts together giving you a part that is almost inscribable all ABS For acrylic sheet I use Weldon 16 and that welds the parts together. For Acrylic cast sheet I use weld on 40 and you can see in my sculptures that it becomes as one, all Acrylic. The picture of what I sell as Lucite_Colorblends I sell at art shows. This keeps me out of trouble Been dicking with plastic professionally for 50 years this year. Best Bob B |
Nor.Cal.914 |
Apr 29 2024, 08:00 AM
That actually looks better than I expected with it completely removed, but I do like the look of it with the grille there still! |
Nor.Cal.914 |
Apr 29 2024, 08:05 AM
On my '73 conversion w/ AC/Heat I gutted the box leaving it in place with drain tubes to remove/divert any water I happen to encounter. (IMG:style_emoticons/default/beerchug.gif) Definitely thought about this, but I'm loving how much open space there is in there already without the vent flaps and tubing. Not sure that I will even do anything with the open space, but it is nice to look at, much less clutter! (IMG:style_emoticons/default/biggrin.gif) I have mine closed off. Bent sheet metal, some 1/4 inch foam tape to seal and a drain hole with tubing to the underside. Not sure why I did this, car is not driven in the rain. Best, Mark I will be either going this route or the ABS plastic route, just need to get the box out then I'll figure it out! It's all fine and fun until the windshield gets fogged up. Agreed, but mine is only going to be a warm weather car now and as I mentioned earlier, I don't feel like my HVAC system helped me much overall during times where I really needed it. |
barefoot |
Apr 30 2024, 12:02 PM
Senior Member Group: Members Posts: 1,272 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
When i got mine, it had a SS plate under the cowl vent. I removed it and installed all the normal vent stuff. The plate is yours for the postage . i can get you photos if wanted.
Barefoot |
Lo-Fi Version | Time is now: 9th May 2024 - 05:46 AM |
