Tangerine racings shift linkage and bulkhead bushing SO GOOD! |
speed metal army |
Apr 23 2024, 09:56 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Title says it all. Thanks to Chris Foley for such good stuff!
My car shifts so well now its nuts! If youve not tried it, do it. The stock setup, no matter how new the bushings are dont even come close. Why the factory only had one pickup point at the console is beyond me. Tangerines system is how it should have been from the factory! I can actually shift with 100% confidence. It was always a thorn in my side the way the car shifted. That is over!!! Click, Click, Click (IMG:style_emoticons/default/piratenanner.gif) Thanks Mr. Foley for all the rad products!!!! Oh and his shifter adjustment procedure is easy as can be and the most effective ive used. (IMG:style_emoticons/default/beer3.gif) SO HAPPY!! (IMG:style_emoticons/default/biggrin.gif) |
Geezer914 |
Apr 24 2024, 06:37 AM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I installed his linkage along with a Renn shifter, no more "I hope this is the right gear". Foley makes some great stuff !
914Next |
Apr 24 2024, 06:50 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Sounds wonderful. Can you comment on the extensiveness of the install? Can a handy person...but not a mechanic.....handle it? how much interior disassembly or lift work is required?
thx |
Shivers |
Apr 24 2024, 08:01 AM
Senior Member Group: Members Posts: 2,368 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Sounds wonderful. Can you comment on the extensiveness of the install? Can a handy person...but not a mechanic.....handle it? how much interior disassembly or lift work is required? thx I just watched a video where the guy installing the kit did not remove the shifter console from the transmission to do the mods. He cut off the ear , put up the template, marked it and drilled tthe holes. That takes out a lot of work. I'd say if you are handy and take your time you can do it. If you are also doing the firewall bushing you'll need to expose the shifter inside to unbolt the shifter rod that runs through the tunnel. It has to be easier than this. |
GregAmy |
Apr 24 2024, 08:34 AM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
NARP74 |
Apr 24 2024, 08:44 AM
Senior Member Group: Members Posts: 1,061 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Got a link for the video?
Shivers |
Apr 24 2024, 08:45 AM
I just watched a video where the guy installing the kit did not remove the shifter console from the transmission to do the mods. I did both of mine that way. Then that makes it easy enough for most to install. If you have an issue ask here for an answer. Don’t forget pictures to explain the question for dense guys like me |
Shivers |
Apr 24 2024, 08:48 AM
speed metal army |
Apr 24 2024, 09:10 AM
Easy stuff! Took about 2 hours. No need to remove the shifter or splined shift rod in the tunnel to install the bushing.
gereed75 |
Apr 24 2024, 09:38 AM
Senior Member Group: Members Posts: 1,244 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
i have been raving about the shifting improvement ever since i installed mine 3 years ago. really improves the shifting Takes all the wiggle waggle out of the shifter rod back at the console and translates it into the exact fore aft and rotational motion the shift shaft needs to efficiently operate the gear selection lever, Brilliant.
I am using the Weltmiester short shift kit up at the shifter Coming out of the 1 - 2 detent is still notchy but once into the H the shifting is actually precise! |
Olympic 914 |
Apr 24 2024, 09:56 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
i have been raving about the shifting improvement ever since i installed mine 3 years ago. really improves the shifting Takes all the wiggle waggle out of the shifter rod back at the console and translates it into the exact fore aft and rotational motion the shift shaft needs to efficiently operate the gear selection lever, Brilliant. I am using the Weltmiester short shift kit up at the shifter Coming out of the 1 - 2 detent is still notchy but once into the H the shifting is actually precise! I have the J West shifter, bronze console bushing and the Tangerine firewall bushing. I thought it shifted as good as it could get. UNTIL I drove Gereed75 car. His is much smoother shifting, where mine is positive but notchy going into all the gears. I have been considering the Tangerine console since then. One of these days..... |
914werke |
Apr 24 2024, 08:46 PM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
"He cut off the ear, put up the template, marked it and drilled the holes." I still have the original Jwest shifter kit in a box somewhere. (IMG:style_emoticons/default/shades.gif) When it came to installing the kit I had a hard time cutting up the stock console, the holes ...no biggie, but there is no going back with this design (IMG:style_emoticons/default/idea.gif) |
Apr 24 2024, 09:12 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
"He cut off the ear, put up the template, marked it and drilled the holes." I still have the original Jwest shifter kit in a box somewhere. (IMG:style_emoticons/default/shades.gif) When it came to installing the kit I had a hard time cutting up the stock console, the holes ...no biggie, but there is no going back with this design (IMG:style_emoticons/default/idea.gif) I don’t think you’d want to. I have the jwest version. If you really wanted to go back to stock, just get a console from an old trans. |
speed metal army |
Apr 25 2024, 09:03 AM
"He cut off the ear, put up the template, marked it and drilled the holes." I still have the original Jwest shifter kit in a box somewhere. (IMG:style_emoticons/default/shades.gif) When it came to installing the kit I had a hard time cutting up the stock console, the holes ...no biggie, but there is no going back with this design (IMG:style_emoticons/default/idea.gif) No going back!? GOOD RIDDANCE!!! (IMG:style_emoticons/default/biggrin.gif) Im sure if someone actually thought the stock setup was better we could always have their head examined! (IMG:style_emoticons/default/laugh.gif) |
mm911 |
Apr 25 2024, 09:35 AM
Newbie Group: Members Posts: 9 Joined: 18-January 13 From: martin tennessee Member No.: 15,385 Region Association: None |
Title says it all. Thanks to Chris Foley for such good stuff! My car shifts so well now its nuts! If youve not tried it, do it. The stock setup, no matter how new the bushings are dont even come close. Why the factory only had one pickup point at the console is beyond me. Tangerines system is how it should have been from the factory! I can actually shift with 100% confidence. It was always a thorn in my side the way the car shifted. That is over!!! Click, Click, Click (IMG:style_emoticons/default/piratenanner.gif) Thanks Mr. Foley for all the rad products!!!! Oh and his shifter adjustment procedure is easy as can be and the most effective ive used. (IMG:style_emoticons/default/beer3.gif) SO HAPPY!! (IMG:style_emoticons/default/biggrin.gif) I agree. Dr. Evil rebuilt my transmission, bought the Tangerine Racing linkage and bearing and the Rennshift. Best shifting 914 I have ever had. Well worth the price. |
913B |
Apr 25 2024, 11:31 AM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
if you remove the shifter console from trans I am assuming all the gear oil would dump out ??
914werke |
Apr 25 2024, 12:30 PM
if you remove the shifter console from trans I am assuming all the gear oil would dump out ?? Unless you drain it first (IMG:style_emoticons/default/biggrin.gif) |
Shivers |
Apr 25 2024, 12:33 PM
914werke |
Apr 25 2024, 12:34 PM
"He cut off the ear, put up the template, marked it and drilled the holes." I still have the original Jwest shifter kit in a box somewhere. (IMG:style_emoticons/default/shades.gif) When it came to installing the kit I had a hard time cutting up the stock console, the holes ...no biggie, but there is no going back with this design (IMG:style_emoticons/default/idea.gif) Well nowadays as cars are more & more being "restored" folks want options. Yes its possible to source a replacement console, but if you dont have to...is betta (IMG:style_emoticons/default/sunglasses.gif) |
Shivers |
Apr 25 2024, 12:44 PM
Easy to go back on mine. Like that is going to happen (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 9th May 2024 - 04:06 AM |
