| DaveB |
Sep 21 2023, 07:54 PM
Member ![]() ![]() Group: Members Posts: 173 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest
Like the title says...
![]() That is all that was left. DaveB |
| infraredcalvin |
Sep 21 2023, 08:05 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,778 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Ooof, that’s not going to come out easy… sharp edges on those cam bearings…
| Superhawk996 |
Sep 21 2023, 08:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,138 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
look around for them
Would be highly unusual for a dog to chew and swallow oddly shaped metal object like a cam bearing. If they truly were swallowed I’d be concerned for the pooches health unless it’s the size if an Irish Wolfhound and can pass something like that. |
| DaveB |
Sep 22 2023, 12:01 AM
look around for them Would be highly unusual for a dog to chew and swallow oddly shaped metal object like a cam bearing. If they truly were swallowed I’d be concerned for the pooches health unless it’s the size if an Irish Wolfhound and can pass something like that. This is Monty. He is a 100lbs and a strong chewer. I took this picture after returning from the vet getting x-rays. Stomach and digestive system are clear. He knows he did something. Lessons learned to keep my work in the garage. I just got the crankshaft, crank and cam bearings and put them inside near the front door. Took the case in the garage, came back and realize the cam bearings were gone. We are now going through the entire house and yard. DaveB |
| Geezer914 |
Sep 22 2023, 05:29 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,373 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Thankfully the dog is ok. I see pieces of the box, did he actually chew a bearing?
| 930cabman |
Sep 22 2023, 09:10 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,864 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Man's best friend?
X-rays are clear? Guilty as can be!! 100lbs, bet there's some force in those chompers? How much are new cam bearings? maybe need to spend more time with the beast |
| friethmiller |
Sep 22 2023, 12:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
Heck! By the time you sand the bite marks out of the bearings, your new cam will probably just be starting to spin free. (IMG:style_emoticons/default/biggrin.gif) Assuming you find them first!
| Shivers |
Sep 22 2023, 12:41 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,669 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
100 lbs, I’d be thankful he didn’t bury the crankshaft in the backyard. (IMG:style_emoticons/default/sad.gif)
| worn |
Sep 22 2023, 08:33 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,654 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Heck! By the time you sand the bite marks out of the bearings, your new cam will probably just be starting to spin free. (IMG:style_emoticons/default/biggrin.gif) Assuming you find them first! When I was growing up the dog would take my eye glasses from beside my bed and bury them in the carpet behind the sofa. I cannot see without glasses. |
| sixnotfour |
Sep 22 2023, 08:40 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,392 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
my 16 pound Dog...Charlie has Huge separation anxiety... He tore the metal off our back door and pulled all the foam insulation out,, outer tin all that's left... Not a scratch on him....We Learned he he can not be left alone... Now has a steel cage ... for alone time ..Its pretty bent up,, but he is adapting... Love Him..
| sixnotfour |
Sep 22 2023, 08:42 PM
triple post
| sixnotfour |
Sep 22 2023, 08:46 PM
| technicalninja |
Sep 23 2023, 08:17 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
One of our keeshonds ate my wife's glasses.
Ate all of the plastic frames but didn't ingest the lenses. Glasses were under "warranty" and they accepted the "hail damaged" looking lenses with hundreds of tiny teeth marks on them and gave us a new pair! The tech at the eyewear shop said that was pretty common as the dog was after the salt in the frames. Killer warranty! BAD DOG! |
| Front yard mechanic |
Sep 23 2023, 11:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,478 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
I too have a dog that likes tools, bolts, car parts etc. every now and then I use my metal detector in the lawn to search
| iankarr |
Sep 23 2023, 11:26 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Good thing they don't make bearings the proper size anymore (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 19th October 2026 - 07:17 PM |
