8 Pages V  1 2 3 > »
> 72 rustoration / subaru 6cyl project in Kansas, Mild resto-mod build, my idea of a “true” sportscar
Alain V.
post Jan 2 2022, 03:40 PM
Well, I suppose I’ve put it off long enough.
I’m finally starting a build/progress page on my 72 914 project.
About the car: I’ve owned it for over a decade, and had it set aside as a quick & easy restoration project, because I “fooled” myself into thinking I had a fairly “rust free” example.
I work, a lot of hours (self employed) and own multiple project cars, so I didn’t start working on this car until recently.
...once I did “start” on it,,,, I became painfully aware of just how bad the car actually was.
The plan, since I ended up stripping the car down to the bare tub, I decided to build my idea/vision of a true sports car.....
In my opinion, the 914 is a perfect “canvas” for such a build. Focus will be on:
Light weight, handling, simplicity, and fun t o drive.
Goal weight is around 1800 pounds, using some carbon deck lids, GT style engine cover, etc.
Goal HP around 250 plus, will come from a Subaru 6cyl.
About me, My background is as an Indy mercedes mechanic for just over 40 years. I’ve never done rust repair or bodywork myself though, as I’ve always hired out those types of jobs. This little 914 is going to be my “tech school” into metal work as a spare time project. Hopefully I’ll be able to work on it one day per weekend on it and possible make monthly updates. I guess we’ll have to see...........
Here she is... when I initially started
Alain V.
post Jan 2 2022, 03:42 PM
“Hell hole” area didn’t look too bad, at first.Attached Image
Alain V.
post Jan 2 2022, 03:45 PM
Outside of jack pad area looked a little roughAttached Image
Alain V.
post Jan 2 2022, 03:46 PM
Had typical holes across the rear of the trunk floorAttached Image
Alain V.
post Jan 2 2022, 03:48 PM
Rear of floor pan looked not too bad.Attached Image
Alain V.
post Jan 2 2022, 03:50 PM
First little surprise was bondo hiding a hole here.Attached Image
Alain V.
post Jan 2 2022, 03:51 PM
Dropping the drivetrain out.Attached Image
Alain V.
post Jan 2 2022, 03:54 PM
Yup, both sides had little bubbles that just grew into holes as I picked at them.Attached Image
Alain V.
post Jan 2 2022, 03:55 PM
Alain V.
post Jan 2 2022, 03:57 PM
This stuff is “The Devil” boooooo! Eats 914s from the inside out![s]Attached Image
Alain V.
post Jan 2 2022, 03:59 PM
I even yanked out the old crusty wiring harness. I’ll be replacing it with my own custom harness which will be much simpler and lighter. Going to use GT style cables on the headlights, so I will be eliminating the front headlight motors, etc.
Alain V.
post Jan 2 2022, 04:01 PM
Floor pan actually seems saveable. Just has a bad spot in the front left cornerAttached Image
Alain V.
post Jan 2 2022, 04:02 PM
Trunk floor is Swiss cheeseAttached Image
Alain V.
post Jan 2 2022, 04:05 PM
It must have been in a small rear end collision at one time. The tail panel was loaded with a ton of bondo and was a wrinkled mess. I’ll be using one from a donor car Attached Image
Alain V.
post Jan 2 2022, 04:08 PM
Went ahead and made up some door opening braces. I mounted them inboard so I can still fit the doors on the car while the braces are in.Attached Image
Alain V.
post Jan 2 2022, 04:11 PM
Starting to make cross braces and supports for a cart for the car. Borrowed the idea from I believe ,MR Hall’s build here.Attached Image
Alain V.
post Jan 2 2022, 04:12 PM
Cart constructionAttached Image
Alain V.
post Jan 2 2022, 04:15 PM
Rear suspension mount. Also added one at the trans mount area and a support under the firewall/floor pan area.
Alain V.
post Jan 2 2022, 04:17 PM
Time to start the rust huntAttached Image
Alain V.
post Jan 2 2022, 04:19 PM
First “lesson learned”. I should have left the door latch area installed and just cut the door jam around it. Attached Image
8 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 12th March 2025 - 05:18 AM
