| 914Mels |
Nov 29 2021, 07:59 PM
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Does anyone have a source for the wire ends that go to the d jet injectors? I don't need the whole plastic end, just the wire connector with or with out the wire. I see standard motor product sells the whole thing but I'd rather buy just the connector itself.
| Mikey914 |
Nov 29 2021, 08:05 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Attached thumbnail(s) |
| Mikey914 |
Nov 29 2021, 08:08 PM
Should be 20% off til midnight. So if you do buy it before midnight pacific we will adjust it down 20% and refund it.
Mark |
| 914Mels |
Nov 29 2021, 08:16 PM
Thanks for the fast reply. On another note, any idea when the perlon carpet kits will be back in stock?
| Mikey914 |
Nov 29 2021, 08:19 PM
We are working on a new upgraded version of these now. Will be ready in the next few weeks. PM me your contact info, I'll have Kenzie drop you a call when they are done.
| 914Mels |
Nov 29 2021, 08:38 PM
Thanks
| Van B |
Nov 29 2021, 08:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
Hey mark, how about spring clips for Bosch connectors on L-Jetronic?
| JamesM |
Nov 30 2021, 06:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,270 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
| Mikey914 |
Nov 30 2021, 06:48 PM
| 914Mels |
Nov 30 2021, 08:19 PM
| JeffBowlsby |
Nov 30 2021, 08:53 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,306 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
DP
| JeffBowlsby |
To be sure you know what you want, this is the D-Jet terminal
| JeffBowlsby |
Nov 30 2021, 08:54 PM
And this is the L-Jet terminal. They are not interchangeable.
| Van B |
Nov 30 2021, 09:03 PM
I was picking up the thread since the OP got his question answered. I’m looking for the retaining clip, not connectors. The stainless wire box shaped clips that hold the plug together. I’m holding my AFM and CSV together with safety wire currently (IMG:style_emoticons/default/rolleyes.gif)
Lo-Fi Version | Time is now: 9th July 2026 - 07:03 PM |
