| Greg914-6GT |
Jan 12 2021, 03:16 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 18-June 14 From: Tampa, FL Member No.: 17,501 Region Association: South East States |
| mepstein |
Jan 12 2021, 03:35 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,906 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
How about a link to your car and not just the pca classifieds. (IMG:style_emoticons/default/beerchug.gif)
| Racer |
Jan 13 2021, 07:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
The link didn't work for me.. but I figured it out... I think you have to be a PCA member.. The link I copied just brought me to the PCA Mart landing page.. Then had to dig under both 914 and "racercar" options and found this. Copied and pasted accordingly. Looks like there could be more pics on the PCA site...
QUOTE 1975 Race Car Published: 01/12/2021 -$52,000 Share Tweet Ad#: 48314 Exterior: Blue Generation: Race Car Interior: Black Transmission: 5-Speed manual Body Style: Targa VIN: 475906187 YOU MUST BE A MEMBER OF PCA TO CONTACT SELLER, OR JOIN OUR PCA TEST DRIVE PROGRAM About This Car Previous owner died, so I don't know the history. Original build sheet consisted of the following modifications: 914/4 chassis Chassis stripped and tubing installed for safety and reinforcement. As much sheet metal removed as possible and a Sheridan wide body kit installed. Rear wing plates and front splitter molded using lite weight fiberglass with micro bubbles, I removed them, but still have them. Custom side window inserts fabricated. GT Racing roof panel installed. Brake cooling ducts and oil cooler box fabricated. GT Racing rear bumper. Suspension & Brakes Front control arms from a 911 Turbo with urethane bushings Turbo tie rods Bilstein RSR front struts with raised spindles Drilled torsion bars 911 Turbo front brake calipers Wrightwood racing front rotor hats and rotors Pagid blue race pads Adjustable front sway bar. Trailing arms reinforced Koni Race rear shocks with Eibach sprngs. Adjustable rear sway bar, removed, but I still have. 911 Turbo rear calipers custom machined to fit. 911 Turbo rear brake rotors. Pagid yellow race pads 9in Fuchs wheels front and 11in CMW wheels rear Engine & transaxle 2.4 liter engine case align bored and shuffle pinned ARP head studs 2.8 RSR Mahle piston and cylinder set. Carillo rods. Crankshaft balanced, lighted and knife edged. 911 Turbo oil pump. Heads twin plugged with over sized valves and ported and flowed. 2.8 RSR camshafts Intakes port matched. High butterfly throttles. Mechanical pump from Gus Pfister Oil lines and cooler by Mariah metal fabrication Headers and mufflers custom made by Kooks. Additional exhaust with umbrella mufflers 901 Transmission Lightweight flywheel and clutch assembly Modification since I have owned the car, work was done by Zotz's Racing: Replace ignition with JB Racing distributor for 12 plugs, and two MSD boxes Large Oil cooler in the front bumper 20 Gallon Fuel Cell Hoosier Tires Repaint for front body, add brake ducts |
Lo-Fi Version | Time is now: 14th September 2026 - 08:51 PM |
