Quick sanity check / look OK? |
Tdskip |
Jan 17 2020, 10:40 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
barefoot |
Jan 17 2020, 12:32 PM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
That exhaust system is stock 75-76 vintage, so it that's what you're after good to go.
Barefoot |
Tdskip |
Jan 17 2020, 12:34 PM
Thanks @barefoot , first time putting on of these later ones on so better to ask now then after I've dropped everything (existing exhaust is wildly custom and won't work).
SirAndy |
Jan 17 2020, 12:35 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
first time putting on of these later ones on so better to ask now then after I've dropped everything (existing exhaust is wildly custom and won't work). In that case, do you have a muffler hanger that will work for the new setup? You can't just have that boat anchor of an exhaust hang off the back like that without any support. And do you have the correct stub pipes that mount to the heads? (IMG:style_emoticons/default/idea.gif) |
rhodyguy |
Jan 17 2020, 12:55 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Do you have the rest of the parts for installation? As Andy mentioned, those dual muffler exhausts weigh a bunch. Plan on leaving the rear valance off unless you have one that you don't mind ruining.
Jan 17 2020, 02:09 PM
I'm made of metal Group: Members Posts: 3,916 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Do you have the rest of the parts for installation? As Andy mentioned, those dual muffler exhausts weigh a bunch. Plan on leaving the rear valance off unless you have one that you don't mind ruining. When I briefly ran with a double-dual tip exhaust it fit under the stock valence. YMMV though. Only lasted a few months before I got wise and backdated the whole system. |
brant |
Jan 17 2020, 02:54 PM
914 Wizard Group: Members Posts: 11,614 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Let me know if you need stub pipes
I found a second pair that n my junk last night |
sixnotfour |
Jan 17 2020, 03:56 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I had that same version on my 73 daily driver.76-2.0. It was well..loud...probably due to age of driver and exhaust..or both....
76 2.0 FI , late model exhaust. With 2 plugged no power loss , No droning, decent sounding. 3 plugged quiet and some top end power loss. Everday to and from work 10 miles , I will plug 3 , needing to travel further ie; freeway etc, I will run 2 open 2 closed If I want to feel racy and annoy everyone including myself 4 open. = that guy Attached image(s) |
Chi-town |
Jan 17 2020, 04:49 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
I have a 75-76 hanger if you need it
mtndawg |
Jan 17 2020, 05:53 PM
Member Group: Members Posts: 413 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
Wow! That's a nice looking set of 1975 HE's.
Jett |
Jan 17 2020, 06:46 PM
Senior Member Group: Members Posts: 1,635 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Tdskip |
Jan 18 2020, 07:56 AM
first time putting on of these later ones on so better to ask now then after I've dropped everything (existing exhaust is wildly custom and won't work). In that case, do you have a muffler hanger that will work for the new setup? You can't just have that boat anchor of an exhaust hang off the back like that without any support. And do you have the correct stub pipes that mount to the heads? (IMG:style_emoticons/default/idea.gif) @SirAndy - the engine has matching (correct for the year) stub pipes, or at least it looks like it to my eyes. I have a muffler hanger from a later 2.0L car so I think I am OK here, but need to get everything in place later today to know for sure. |
Tdskip |
Jan 18 2020, 07:57 AM
I have a 75-76 hanger if you need it @Chi-town - thanks, may need to run over for that if I have the wrong one on hand. I did just open a package from Pelican only to find I ordered the wrong exhaust to muffler gaskets. (IMG:style_emoticons/default/headbang.gif) |
Tdskip |
Jan 18 2020, 07:59 AM
Do you have the rest of the parts for installation? As Andy mentioned, those dual muffler exhausts weigh a bunch. Plan on leaving the rear valance off unless you have one that you don't mind ruining. @rhodyguy - huh, wasn't thinking it was going to cause an issue with the valance. Guys - should I just try to quickly track down a stock or closer to stock muffler? |
Tdskip |
Jan 18 2020, 08:01 AM
I had that same version on my 74 daily driver.76-2.0. It was well..loud...probably due to age of driver and exhaust..or both.... 76 2.0 FI , late model exhaust. With 2 plugged no power loss , No droning, decent sounding. 3 plugged quiet and some top end power loss. Everday to and from work 10 miles , I will plug 3 , needing to travel further ie; freeway etc, I will run 2 open 2 closed If I want to feel racy and annoy everyone including myself 4 open. = that guy Thanks @sixnotfour - this muffler was given to me and I was planning on just using it to get the car back on the road. I've heard, ha, other people caution that it is pretty loud. Never occurred to me to simply plug one or more of the tips - clever. |
Tdskip |
Jan 18 2020, 08:02 AM
Let me know if you need stub pipes I found a second pair that n my junk last night Thanks @brant , think I am OK but very helpful of you to offer up. |
Jett |
Jan 18 2020, 12:35 PM
I have a Bursch exhaust from local member, and although it appeared unused it had a bit of shelf scratching so we painted. That said, we ended up finding a stock muffler, and not installing the Bursch unit.
Shipping might be expensive, but you can have the muffler with gaskets and new exhaust nuts for $200 + shipping (actual cost). http://www.burschexhaust.com/75-76-914-1-8...et-Muffler.html If you are interested, I’ll take some pics |
Tdskip |
Jan 18 2020, 02:05 PM
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured.
Thank you for the post however, hopefully someone else can make good use of it. |
Jett |
Jan 18 2020, 02:14 PM
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured. Thank you for the post however, hopefully someone else can make good use of it. good deal (IMG:style_emoticons/default/smile.gif) |
Jan 18 2020, 03:52 PM
Thanks Jett. As it turns out a local 914 world guy reached out to me yesterday afternoon and I literally just picked up a more stock set up that I will be installing instead of the one I pictured. Thank you for the post however, hopefully someone else can make good use of it. So did you get early stock HE's? or SSI's? T1 and 4 any time I've tried a 4-1-2 system it's loud as fuch, on my bus it was so bad I capped one of the tips off. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:02 PM |
