New Part Porn |
New Part Porn |
Oct 7 2019, 07:25 PM
G50 PEDAL HOUSING
Attached thumbnail(s) |
76-914 |
Oct 8 2019, 09:03 AM
And your plans are....................................................... (IMG:style_emoticons/default/confused24.gif)
aturboman |
Oct 8 2019, 09:06 AM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Another dozen parts and some extra fabrication and you can have a factory hydraulic clutch set-up with non power brakes for 914-6
76-914 |
Oct 8 2019, 01:23 PM
Ahah. (IMG:style_emoticons/default/popcorn[1].gif)
Oct 8 2019, 01:56 PM
And your plans are....................................................... (IMG:style_emoticons/default/confused24.gif) Belongs to a customer for rebuilding his rusty pedal set. |
IronHillRestorations |
Oct 8 2019, 01:58 PM
You are such a perv. Porsche parts perv that is (IMG:style_emoticons/default/smile.gif)
Oct 9 2019, 07:32 AM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Another dozen parts and some extra fabrication and you can have a factory hydraulic clutch set-up with non power brakes for 914-6 And it won't fit into a 914 pedal box. Not enough room for the clutch master to clear the front wall. Been there, done that. Plus, the clutch master won't work with anything but a G-50 trans. It's too small for a Boxster/Cayman trans. Done that one too.... |
76-914 |
Oct 9 2019, 08:02 AM
Offhand, what is the diameter of the slave cylinder?
Oct 9 2019, 09:24 PM
Offhand, what is the diameter of the slave cylinder? Small. I estimate 15mm. I have one at the shop I can measure. The size of the master is related to the slave that can be used. If you are thinking about a hydrogen. Clutch got Summit Racing and look at components. |
Oct 11 2019, 08:23 PM
@76-914 date='Oct 9 2019, 07:02 AM' post='2753391']
Offhand, what is the diameter of the slave cylinder? [/quote] The G50 master is 19mm |
Lo-Fi Version | Time is now: 25th April 2024 - 11:18 PM |
