> WTB a few small parts, Found some bits but need more
post Aug 2 2019, 01:33 AM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor.
Need;
1 x metal 3 bolt spacer behind crank fan
1 x thermostat mounting bracket ,found one online
2 x small spring steel tabs that hold the fan housing flap pivot rod.
1 x crankcase metal cover and bolt for oil strainer
1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate.
1 x 3 pin altenator plug
1 x working thermostat, found one thanks Mike B
1 x dipstick
Still looking thanks.
Shipping to Portland Oregon 97203.
TIA.
Tbone425
post Aug 2 2019, 07:14 PM
QUOTE(porschetub @ Aug 2 2019, 12:33 AM) *
Need;
2 x thermostat mounting brackets
2 x dizzy clamps
1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012.
TIA.
I might have some of this stuff in my free bin at the John Walker Porsche swap meet tomorrow in Seattle.
Tbone425
post Aug 2 2019, 07:19 PM
Need;
2 x dizzy clamps
TIA.
I have an ....020 afm no ide if it will work, but you can have it if you think it will.
post Aug 2 2019, 07:51 PM
PM on the way,thanks so much (IMG:style_emoticons/default/biggrin.gif) .
post Aug 13 2019, 02:10 PM
QUOTE(porschetub @ Aug 2 2019, 07:33 PM) *
Need;
1 x metal 3 bolt spacer behind fan
3 x small spring steel tabs that hold the fan housing flap pivot rod
1 x working thermostat (yes I know),a T1 original would do.
TIA.
Dominic
post Aug 13 2019, 06:49 PM
Dominic
I should have the following parts, but I will need a few days to find all of them:
2 x thermostat mounting brackets (I know I have at least one)
1 x working thermostat (I have a T1 thermostat)
Thanks,
Dominic
Mblizzard
post Aug 13 2019, 07:29 PM
I have a dizzy clamp and thermostat.
post Aug 14 2019, 12:42 AM
Thanks Mike and Dominic ,keen as thanks
post Aug 14 2019, 05:11 PM
QUOTE(Tbone425 @ Aug 3 2019, 01:19 PM) *
Need;
2 x dizzy clamps
TIA.
Still keen to sell the AFM if you still have it?,cheers.
post Aug 14 2019, 10:59 PM
QUOTE(Dominic @ Aug 14 2019, 12:49 PM) *
Thanks,
Dominic
Cheers when you get time will take all,thanks.
post Aug 16 2019, 03:46 PM
Need;
3 x small spring steel tabs that hold the fan housing flap pivot rod.
1 x working thermostat (yes I know),a T1 original would do as better than nothing.
1 x dipstick
TIA.
post Aug 28 2019, 08:31 PM
Need;
1 x dipstick
TIA.
Bump.
post Aug 28 2019, 09:37 PM
QUOTE(porschetub @ Aug 29 2019, 02:31 PM) *
Need;
1 x dipstick
TIA.
Bump.
Have found thermostat thanks to Mike B.
Still need the rest,thanks.
post Sep 14 2019, 01:58 PM
Need;
1 x dipstick
TIA.
BUMP
post Sep 20 2019, 02:22 AM
Need;
1 x dipstick
TIA.
BUMP.
post Sep 23 2019, 01:35 PM
Still need;
1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate .
Thanks.
TIA.
- Lo-Fi Version Time is now: 25th September 2026 - 11:12 AM
