| seanpaulmc |
Dec 25 2016, 04:26 PM
Member ![]() ![]() Group: Members Posts: 397 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
I've just purchased a '73 914 and owned it long enough to ship it to Orlando and take it to go get titled. With only having it for this short period my list of concerns is growing. I have no intentions of driving the car around until I can assess how rusty it is. I appreciate the support and responses to the questions about transportation and engine identification. This is a superb community.
What advice do you have for lifting the car to inspect underneath and such without having access to a lift? I have read some of the build threads on here and you guys have some amazing shops and do incredible work! ...one day. But, at this point I don't have that. For now I'd like to lift the car, take the wheels off, and take the longitudinal covers off to get a good look at the structural areas of the car. However, I have concerns because this is a snowbelt car and I've read the stories about putting a floor jack through a rusted out car. Where should I lift with the floor jack (trust the jacking points?, other areas) and where should I put the jack stands so that I can poke around some and get pictures? Merry Christmas!!! |
seanpaulmc How to inspect the underside and longs without a lift Dec 25 2016, 04:26 PM
Rand Don't worry about lifts and jacks yet. Just st... Dec 25 2016, 04:34 PM
mepstein Start cleaning the trunks and interior of your car... Dec 25 2016, 04:59 PM
branston I don't jack my '74 under the body, I tend... Dec 25 2016, 10:01 PM
seanpaulmc I finally got some time and pulled the covers off ... Jan 31 2017, 05:01 PM
Dave_Darling A 2x4 can distribute the load from the jack across... Jan 31 2017, 05:39 PM
JoeDees You're gonna need to buy a welder. Jan 31 2017, 05:11 PM
r_towle
Yup May 8 2022, 07:06 PM
mepstein You need long and floor pan repair. Once you scrap... Jan 31 2017, 05:16 PM
seanpaulmc Thanks for the feedback, All.
About that welder... Feb 1 2017, 04:49 PM
DennisV
About that welder, is there advice for a recommen... Aug 27 2023, 04:15 PM
Ferg Whats the code for the original color on this car?... Feb 1 2017, 04:57 PM
seanpaulmc
L96M
Original is a light blue metallic. Current... Feb 1 2017, 05:35 PM
Ferg
L96M
Original is a light blue metallic. Curren... Feb 1 2017, 05:47 PM
amfab Your longs and pans look like they have similar is... Feb 1 2017, 05:52 PM
JoeDees There will be a lot of opinions on the welder (and... Feb 1 2017, 06:06 PM
branston
There will be a lot of opinions on the welder (an... Apr 1 2017, 07:32 PM
PanelBilly There's some smart people with the skills to h... Feb 1 2017, 07:29 PM
mepstein How about the hell hole?
You can see the suspensi... Feb 1 2017, 08:03 PM
Larmo63 You should assess everything under the tar padding... Feb 1 2017, 08:10 PM
seanpaulmc Here's the initial look underneath. I'm p... Apr 1 2017, 06:52 PM
Dave_Darling
The engine cradle is cockeyed (i.e. not vertical)... Apr 2 2017, 01:16 PM
Robarabian Duplicate post. Sorry.
Here's the initial lo... Mar 3 2021, 10:33 PM
branston
If your webbing doesn't clean up or the retr... Apr 2 2017, 01:42 PM
boxsterfan You are definitely going to need to order from the... Apr 2 2017, 02:26 PM
seanpaulmc
You are definitely going to need to order from th... Mar 3 2021, 07:11 PM
930cabman Time, patience, basic skills, repeat, repeat and d... Mar 3 2021, 07:24 PM
seanpaulmc Hard to believe this tread was stared four years a... Mar 3 2021, 07:30 PM
seanpaulmc Let's see what we're working with. Or, wi... Mar 3 2021, 07:55 PM
seanpaulmc 5/8/22 - might as well make it a project thread.
... May 8 2022, 05:30 PM
seanpaulmc I'm using 18 gage gavaneal and a lot of self t... May 8 2022, 05:41 PM
seanpaulmc Links to threads on some of the other repairs: :t... May 8 2022, 05:50 PM
seanpaulmc Starting to patch the firewall.
Using those c... May 8 2022, 06:06 PM
seanpaulmc Passenger Jack Point repair:
Peeing back the ... May 8 2022, 06:33 PM
930cabman Great looking work, keep your focus and she will b... May 9 2022, 07:06 AM
seanpaulmc Been a while for an update. With it raining like i... Aug 14 2022, 02:43 PM
seanpaulmc Now that I've cut my teeth on the Hell hole re... Aug 14 2022, 03:01 PM
seanpaulmc Clearly the plan was to work on getting the new fl... Aug 14 2022, 03:21 PM
seanpaulmc And, for a change of pace worked on something else... Aug 14 2022, 03:27 PM
Puebloswatcop Hey, things are looking good so far. as for the c... Aug 14 2022, 05:33 PM
seanpaulmc Working on the passenger side floor fit up. :saw... Aug 22 2022, 03:33 PM
DRPHIL914 good work! keep on trucking! great you are... Aug 22 2022, 04:28 PM
Dave_Darling Double-check the roll pin on your pedal cluster th... Aug 22 2022, 05:22 PM
seanpaulmc
Double-check the roll pin on your pedal cluster t... Aug 22 2022, 05:26 PM
930cabman Great progress and all this while working on your ... Aug 23 2022, 08:37 AM
seanpaulmc For a Safe, Quick, and simple way to remove the sp... Aug 26 2022, 08:09 AM
seanpaulmc Working towards installation of the passenger side... Aug 26 2022, 08:24 AM
930cabman From what I know it was coated with cosmoline when... Aug 26 2022, 04:51 PM
seanpaulmc Well it’s been a while.
Where was I?
Right, a ... Feb 21 2023, 06:57 PM
bajafreaks
Where was I?
Right, a... May 29 2023, 08:06 AM
Cairo94507 Great work and progress. :beer2: Feb 22 2023, 08:25 AM
seanpaulmc Looking for some pictures of how this section at t... Feb 23 2023, 09:15 AM
930cabman Quality of workmanship looks great, keep it going ... Feb 23 2023, 10:13 AM
seanpaulmc
Quality of workmanship looks great, keep it going... Feb 23 2023, 10:40 AM
Quality of workmanship looks great, keep it goin... Feb 23 2023, 11:26 AM
Cairo94507 Here is the best shot I have of my car when we wer... Feb 23 2023, 10:18 AM
Root_Werks Marc and I used a Borescope camera to inspect insi... Feb 23 2023, 10:36 AM
seanpaulmc Today…
…all day. :headbang:
Remarkably... Feb 25 2023, 06:54 PM
seanpaulmc Another patch panel. :welder:
Passenger footwel... Mar 11 2023, 07:43 PM
seanpaulmc Moved on to peeling back the rusty onion of the A-... Mar 11 2023, 07:53 PM
seanpaulmc Really for the first time I feel like I am making ... Apr 20 2023, 12:32 PM
930cabman Lookin good, keep on truckin and you will be motor... Apr 20 2023, 01:25 PM
seanpaulmc Mmmmmm parts!
Had to share my excitement. Apr 26 2023, 04:14 PM
East coaster Good metal work. I just did some of those same spo... Apr 26 2023, 08:01 PM
seanpaulmc Been a while for an update… floors are done. At... May 27 2023, 05:20 PM
mgarrison
Been a while for an update… floors are done. A... May 27 2023, 07:20 PM
Dave_Darling Herculiner? Make sure you don't get it on you... May 27 2023, 05:41 PM
East coaster Just sprayed my tub with Custom Coat bedliner (fro... May 28 2023, 05:18 AM
seanpaulmc Thanks for the references on the bed / raptor line... May 28 2023, 09:12 AM
seanpaulmc @bajafreaks
The passenger floor pan I bought fro... May 29 2023, 01:45 PM
bajafreaks
@[url=http://www.914world.com/bbs2/index.php?show... May 29 2023, 06:09 PM
seanpaulmc For review, we last left off with completion of th... Jul 6 2023, 01:27 PM
930cabman Great progress, currently I am repairing some mino... Jul 6 2023, 02:23 PM
seanpaulmc Back at it.
I made up my own replacement corner... Aug 27 2023, 03:29 PM
bkrantz
Back at it.
I made up my own replacement corne... Jul 17 2024, 07:24 PM
seanpaulmc
Back at it.
I made up my own replacement corn... Jul 23 2024, 12:08 PM
seanpaulmc With a little help from you guys I was able to fig... Sep 2 2023, 07:29 PM
930cabman +1 with your progress, all the while working outdo... Sep 3 2023, 05:51 AM
seanpaulmc Put back the old door sill.
Mostly. Almost done ... Sep 9 2023, 06:14 PM
seanpaulmc Sometimes a project reaches a tipping point…
... Jul 7 2024, 07:17 PM
Artfrombama Impressed with your work and tenacity.
Keep up th... Jul 8 2024, 09:24 PM
seanpaulmc Between the rain (daily), family life, and regular... Jul 17 2024, 08:04 AM
seanpaulmc Kind of a wash out last week when outside of day j... Jul 23 2024, 12:21 PM
friethmiller Good job! :trophy: Glad to know I'm not... Jul 23 2024, 01:55 PM
seanpaulmc
Good job! :trophy: Glad to know I'm no... Jul 23 2024, 06:51 PM
friethmiller
[quote name='friethmiller' post='3158074' date='J... Jul 24 2024, 06:37 AM
[quote name='friethmiller' post='3158074' date='... Jul 24 2024, 01:29 PM
seanpaulmc Rain delay today. Workshop closed.
But yesterday ... Jul 25 2024, 06:00 PM
seanpaulmc Roll over jig
I did not come up with this but cou... Jul 26 2024, 07:19 PM
seanpaulmc What’s behind your seam sealer? :angry:
Jul 27 2024, 07:21 PM
seanpaulmc Looking to the weekend ahead and hoping to put in ... Aug 27 2024, 09:27 AM
Geezer914 That's what I did, coated the underside with t... Aug 27 2024, 11:37 AM
friethmiller [Not trying to hijack the thread here with my pics... Aug 27 2024, 12:22 PM
seanpaulmc
[Not trying to hijack the thread here with my pic... Aug 27 2024, 12:50 PM
friethmiller So true about being outside! Part of any rest... Aug 27 2024, 01:26 PM
seanpaulmc Need a waterproof car cover. Thought this was fine... Aug 31 2024, 06:24 PM
seanpaulmc Hot!
No rain today. Welding could be done. :... Aug 31 2024, 06:31 PM
Hot!
No rain today. Welding could be done. ... Sep 1 2024, 05:22 AM
seanpaulmc
Hot!
No rain today. Welding could be done. ... Sep 1 2024, 01:56 PM
seanpaulmc Got the rest of it in just before the heavens brok... Sep 1 2024, 02:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2025 - 05:20 AM |
