| mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
mrbubblehead what did you do to your 914 today Dec 17 2011, 08:07 PM
racerbvd I put a magetic wood dash kit on the dide :shades2... Dec 17 2011, 08:17 PM
ellisor3 I put a new fan belt on my 3.2. What a suck fest. ... Dec 17 2011, 08:20 PM
shuie :sawzall:
cut out my floors Dec 17 2011, 08:25 PM
windforfun Q-tipped its ears. Dec 17 2011, 08:29 PM
Gustl yesterday I put my original leather steering wheel... Dec 18 2011, 12:27 AM
gendent I drove it to Costco, and back. Usually a 15 minut... Dec 18 2011, 12:51 AM
Bob L. I put the bumperetts back on the front and began r... Dec 18 2011, 12:53 AM
PancakePorsche Welded in Autopower roll cage, installed repainted... Dec 18 2011, 01:29 AM
infraredcalvin
Welded in Autopower roll cage, installed repainte... Dec 18 2011, 02:12 AM
cwpeden Started it, wamred it up, turned it off. Then wis... Dec 18 2011, 01:42 AM
etcmss Prep the front suspension for removal..down to the... Dec 18 2011, 06:06 AM
bulitt Picked up a fresh 327 SBC from a Nascar Mechanic. ... Dec 18 2011, 06:43 AM
Phoenix-MN No words needed :shades2: and yes, it's cold ... Dec 18 2011, 12:01 PM
ppetion I started to reassemble the engine. Installing the... Dec 18 2011, 12:07 PM
treborzerimar I replaced my 180 rear springs with 140s yesterday... Dec 18 2011, 12:50 PM
gary gartner I will dust him off, clean up and get reaady for t... Dec 18 2011, 12:54 PM
MrHyde Finished welding a few touchups on the rear floor ... Dec 18 2011, 01:25 PM
mrbubblehead nothing.....its raining....ARGH! :hissyfit: :... Dec 18 2011, 01:45 PM
stugray Finished cleaning the last of my parts fro my Dual... Dec 18 2011, 02:13 PM
mrbubblehead
Finished cleaning the last of my parts fro my Dua... Dec 18 2011, 02:16 PM
warpig Decided to sell mine today :hissyfit: Took it fo... Dec 18 2011, 03:34 PM
1988Hawk Put in new turn signal and washer stalks. Pressur... Dec 18 2011, 05:12 PM
hot_shoe914 I drove the LE to pick up lunch at my favorite Mex... Dec 18 2011, 05:36 PM
JawjaPorsche Drove it to church then did some detailing this af... Dec 18 2011, 05:41 PM
scott_in_nh Let's see it is 25F but sunny in NH....
To it... Dec 18 2011, 06:08 PM
Lou W I moved mine into a storage unit along with all he... Dec 18 2011, 06:25 PM
euro911 Nothing today, but Milt (aka: Zeke) came by the sh... Dec 18 2011, 08:12 PM
dirk9141973 :Qarl: Got it out of storage added qt oil drove it... Dec 18 2011, 08:35 PM
FourBlades Bled my front brakes after tightening up the gland... Dec 18 2011, 09:51 PM
malcolm2
i just wanted to start a thread to see what you g... Dec 18 2011, 09:59 PM
stugray mrbubblehead,
"what type of ultra sonic part... Dec 18 2011, 11:20 PM
euro911 :WTF: ... the regular price has shot up to $9... Dec 19 2011, 12:20 AM
bulitt
:WTF: ... the regular price has shot up to ... Dec 19 2011, 04:48 AM
ellisor3
:WTF: ... the regular price has shot up to ... Dec 19 2011, 07:15 AM
porschefile2010 Mines in bits. Blew the head at #1 cylinder-found ... Dec 19 2011, 02:40 AM
513mugsy Measured up another Porsche for a possible suspens... Dec 19 2011, 04:32 AM
Philip W. yesterday-
I replaced my center console panals w... Dec 19 2011, 09:41 AM
Bob L.
yesterday-
I replaced my center console panals ... Dec 19 2011, 11:59 AM
tradisrad I did nothing to my 914 as my subaru decided to br... Dec 19 2011, 10:05 AM
Andyrew
I did nothing to my 914 as my subaru decided to b... Dec 19 2011, 10:40 AM
tradisrad
Say whaaat?
Broken bar or end links?
The Subar... Dec 19 2011, 11:47 AM
m170seeker I drove all ogver town Christmas shopping. Loaded... Dec 19 2011, 10:38 AM
mrbubblehead wow tradisrad, thats pretty crazy. luckily it happ... Dec 19 2011, 11:56 AM
struckn Turned the Key to On and Fuel pump kicked in, EM B... Dec 19 2011, 02:50 PM
type47
Turned the Key to On and Fuel pump ... and Income... Dec 19 2011, 04:33 PM
jsayre914
Turned the Key to On and Fuel pump kicked in, EM ... Dec 27 2011, 09:05 PM
boogie_man Worked all night long in the hell hole area....rus... Dec 19 2011, 04:38 PM
DblDog OK, it was last Friday...after WAY too long, I... Dec 19 2011, 05:17 PM
SLITS I looked at it.
I started up the six and heated i... Dec 19 2011, 07:07 PM
Krieger Bought her parts! Oil tank seals/spacer, spark... Dec 19 2011, 07:11 PM
bcheney Removed pilot bearing from the flywheel...installe... Dec 19 2011, 07:39 PM
mrbubblehead i installed a new alternator today :Qarl: . no mor... Dec 19 2011, 11:14 PM
mrbubblehead i tore the interior out today in preparation for t... Dec 20 2011, 07:50 PM
aharder Tried to break the 1/2 shafts away from the stud a... Dec 20 2011, 09:03 PM
dangrouche Road bicycle rack finally completed. I had a bunc... Dec 25 2011, 08:45 PM
aharder
Cleanerd my 1/2 shafts :D Dec 25 2011, 09:43 PM
Maltese Falcon I hooked up a Deltran 12 volt tender to the beast,... Dec 27 2011, 08:52 PM
PeeGreen 914 I went and pulled the A-arms off tonight. Next I w... Dec 27 2011, 09:07 PM
nsr-jamie Got my car back from the body shop today as it was... Dec 27 2011, 09:44 PM
Black22 Yesterday I disconnected everything that's inv... Dec 27 2011, 09:56 PM
infraredcalvin Heh heh, new welder for Xmas... Work on installing... Dec 27 2011, 10:18 PM
aharder cleaned parts :beer3: and cleaned more parts :Qarl... Dec 27 2011, 10:18 PM
ppetion Putting the FI parts, new manifold gasket, new gas... Dec 27 2011, 10:39 PM
914.SBC I had a slight exhaust leak so I used it as my exc... Dec 28 2011, 09:27 AM
rdauenhauer Struggled getting the impeller hub off the front o... Dec 28 2011, 10:58 AM
PeeGreen 914
Struggled getting the impeller hub off the front ... Dec 28 2011, 12:12 PM
dlestep Well...while I was laying on my back, working on m... Dec 28 2011, 11:32 AM
reharvey Finally got the trans back together and bolted to ... Dec 28 2011, 12:50 PM
Finally got the trans back together and bolted to... Dec 28 2011, 01:23 PM
RickS
Finally got the trans back together and bolted to... Dec 28 2011, 11:28 PM
reharvey
Finally got the trans back together and bolted t... Dec 29 2011, 01:06 PM
shuie Broke down my rear suspension consoles for new bus... Dec 28 2011, 11:05 PM
fteixeira
Broke down my rear suspension consoles for new bu... Dec 29 2011, 03:10 PM
wndsrfr Last weekend: new rear rotors and rear brake pad c... Dec 29 2011, 07:33 PM
PeeGreen 914 Pressed out the front bushings to prep the A-arms ... Dec 28 2011, 11:38 PM
tradisrad RE: what did you do to your 914 today Dec 29 2011, 08:31 AM
JRust Layed down a coat or primer on my rear trunk :) Dec 29 2011, 09:11 AM
SirAndy what did you do to your 914 today?
Drove it. :dri... Dec 29 2011, 01:05 PM
ewdysar My newly restored rear brake calipers (Ferrari 308... Dec 29 2011, 01:14 PM
reharvey
My newly restored rear brake calipers (Ferrari 30... Dec 29 2011, 01:38 PM
chandler1969 Jumped started the car as the cold weather drains ... Dec 29 2011, 01:45 PM
Harpo I pulled the "A" arms, struts, pedal box... Dec 29 2011, 08:54 PM
Bob L. I drained the gas tank in prep for cleaning out an... Dec 29 2011, 09:51 PM
Strudelwagon I reassembled the drivers door complete with all n... Dec 29 2011, 10:59 PM
Philip W. Tomorrow, or rather this morning( its12:48- watchi... Dec 29 2011, 11:55 PM
Philip W.
Tomorrow, or rather this morning( its12:48- watch... Dec 30 2011, 09:59 PM
stewteral [quote name='mrbubblehead' date='Dec 1... Dec 30 2011, 12:12 AM
oldschool Ive been stick with a fuel problem ...I think? but... Dec 30 2011, 12:52 AM
etcmss windshield-the crack got worse- and trim removal i... Dec 30 2011, 05:57 AM
hot_shoe914 I'm going to drive the LE to work here in abou... Dec 30 2011, 06:36 AM
JawjaPorsche Replaced the fuel injector rubber elbow hoses. Th... Dec 30 2011, 05:10 PM
djm914-6 My car has been my daily driver for two weeks now ... Dec 30 2011, 05:45 PM
aharder All I got to do today was clean parts :(
Now it... Dec 30 2011, 06:05 PM
TC 914-8 Thought it would be a good idea to pull my oil pa... Dec 30 2011, 07:30 PM
Bob L. Got the gas tank out Dec 30 2011, 07:36 PM
raw1298 I added a battery tender charger to mine today. Dec 30 2011, 07:38 PM
SGB I beat on mine with a 10# sledgehammer and jumped ... Dec 30 2011, 08:01 PM
914-300Hemi Installed the new muffler using the bracket from b... Dec 30 2011, 10:05 PM
Philip W. I forgot to add- after I got the fan in and tank b... Dec 30 2011, 10:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 04:43 AM |
