How do YOU protect your transmission case from corrosion?, What coatings do you use? |
Dr Evil |
Mar 8 2010, 10:56 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am trying to finish my notes to accompany the rebuild video (notes will be free) and I am wanting to pick your collective brains for info on corrosion prevention for the mag alloy case. What do you do? The factory coating only lasted a few years and is long gone now. On most peoples cases, it is the oil that keeps it from corroding (IMG:style_emoticons/default/wink.gif)
Krieger |
Mar 8 2010, 10:58 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The one sitting on my garage floor is coated in wd-40 and shows no corrosion after 4 years.
underthetire |
Mar 8 2010, 10:59 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Nickel plating, a little bling bling....
McMark |
Mar 8 2010, 11:24 PM
914 Freak! Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I cover mine with 40 yr old German steel and don't look at it. (IMG:style_emoticons/default/laugh.gif)
sacrifical anode? |
Dr Evil |
Mar 8 2010, 11:29 PM
I know one can clear coat a clean one. There is this stuff called "Gibbs" or something like that which some have tried with success. There is no shortage of people that will clean these things, but they do not know to coat it and they start to deteriorate.
bandjoey |
Mar 8 2010, 11:34 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
MOTOR OIL and dirt works great! (IMG:style_emoticons/default/lol-2.gif)
Dr Evil |
Mar 8 2010, 11:36 PM
I know, I mentioned that (IMG:style_emoticons/default/tongue.gif)
Dr. Roger |
Mar 8 2010, 11:43 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
I try to make sure at least one of my valve cover gaskets are leaking and maybe one other high level oil gasket is giving up a little oil all in the name of protecting my prized 901.
but seriously, http://www.finishing.com/faqs/magnesium.html Dow 17 surface conversion coating if it's Magnesium. |
Rand |
Mar 9 2010, 12:26 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Is corrosion a serious issue? Rust on steel is a horrible cancer that destroys, but the transmissions don't really decay. Is this for purely cosmetic reasons?
Please forgive the dumb Qs, just wondering. I've also seen people paint them... The pros and cons might be worth mentioning in the vid? Can't wait to add the Evil DVD to my library! |
zymurgist |
Mar 9 2010, 05:13 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I think this could apply to /6 fans too... aren't they magnesium?
Not like 914/6 guys ever see their fans, though. (IMG:style_emoticons/default/wink.gif) |
Gint |
Mar 9 2010, 08:42 AM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Never bothered. I might want to at some point though (the six resto), so this thread is a bonus.
Richard Casto |
Mar 9 2010, 08:44 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Mike,
I started a long term test of a few cleaning and protection methods a few years ago. Check this out... http://motorsport.zyyz.com/project_914_03_14.htm Last update was early 2008. Part is still hanging up outside and I need to bring it in and take some more photos. I look at it periodically, but in general I would stand by what I said last time I posted and that is... * Media blasting is the best at cleaning, but it removes the chromate conversion that may still provide some corrosion protection. * Gibbs Brand Penetrating Oil/Lubricant works, but it's not a miracle product. * CRC Heavy Duty Corrosion Inhibitor seems to work the best. This is not surprising since Porsche also used a waxy protectant (Tectyl) on the magnesium transmissions parts. So short of finding a place to buy Tectyl (what the factory used and I can't seem to find anyone who sells it in small quantities), I would go with "CRC Heavy Duty Corrosion Inhibitor". http://www.crcindustries.com/ei/content/pr...N=06026&S=C Occasionally I find this stuff at stores, but generally I have to order it. It is somewhat targeted at boaters, so I have yet to see if boating supply stores carry it on a regular basis. Richard |
Richard Casto |
Mar 9 2010, 08:56 AM
I should also mention that I was looking to go for "period correct" look/style (I also wanted it to be cost effective) with respect to a method to protect the transmission case. Back in the day Porsche used a chromate finish to provide temporary protection to the parts between the time they were machined and when they were assembled. Chromate finish provides decent, but not long term protection. So it was never intended to really protect the case. What Porsche did was spray the assembled case with a product named Tectyl which is a waxy coating. The CRC product above is similar to Tectyl.
If you are not looking for period specific or a low cost solution, then there are many newer coatings (particularly aerospace based) that can be used on magnesium and aluminum. However some of those may result in oddly colored finishes (such as green). You might be able to find someone willing to do another chromate conversion process on a case if you want to replicate the factory finish (particularly the brassy color the chromate finish gives). However most (all?) chromate conversion processes use hexavalent chromium which is nasty stuff. The movie Erin Brockovich is about people who were poisoned by hexavalent chromium. So the stuff is just about outlawed today and may be expensive to have done. I have not put much thought into painting a case and if that is a good idea for the long term. However I know that many people do paint their cases. |
tat2dphreak |
Mar 9 2010, 09:25 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
30 years of grease and gunk are keeping mine pristine underneath (IMG:style_emoticons/default/smile.gif)
pcar916 |
Mar 9 2010, 10:11 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
... would go with "CRC Heavy Duty Corrosion Inhibitor". I'm about to order something myself so this is a timely discussion. I got mighty frustrated last year trying to find Tectyl. But in addition to Richard's suggestion, which is described as "dark amber" have any of you tried CRC 3-36 product as well? http://www.crcindustries.com/ei/content/pr...N=10200&S=Y It's temperature range is up to 300 degrees and it's just plain "amber" which Tectyl is too. I don't know how that compares with the Marine CRC stuff. According to the spec-sheets, the marine stuff appears to be more viscous than 3-36. Here's a newer coating. I don't know anyone using it on one of our cars. http://www.tagnite.com/video/ and http://www.tagnite.com/ Links to Tectyl: http://www.daubertchemical.com/main.taf?p=3,1 http://tectyl2.valvolineeurope.com/index.a...ba0e5105135c4d5 Also, here is a link to an old thread that covers a lot of ground on this topic. http://forums.pelicanparts.com/porsche-911...-corrosion.html Good reading! |
SUNAB914 |
Mar 9 2010, 10:20 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Eastwood, Aluma blast spray.
davep |
Mar 9 2010, 12:43 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Pelican was going to sell Tectyl, but ran into problems with shipping it I believe.
The CRC marine HD material seems to be the best alternative, but it is hard to find. It is possible that only marine stores can get it, our FLAPS cannot. Gibbs brand lube is possibly the next best inhibitor. Talking to local trans shops they just use a spray on lube like WD40. |
Richard Casto |
Mar 9 2010, 02:37 PM
I haven't heard of that CRC 3-36. I read that link and it sounds like a non-drying lubricant (much like Gibbs Brand). If anyone tries it out let me know how it works out.
I haven't tried to buy Tectyl in a few years. Everyone I could find was geared up to provide large quanties. Not to mention the fact that Tectyl is a brand name and not a single product. So you have to make sure you buy the right thing. That PP thread is great and it was the source of PP planning to sell Tectyl. Grady Clay had found a source for Tectyl 846 (which he said is what Porsche used). But for whatever reason (maybe shipping issues as Dave said) that fell apart. I just Googled a few minutes ago and did find a supplier that apparently sells Tectyl 846 in spray cans. They list a case of 12 cans at $76 which I think is reasonable. So I ordered a case. Here is the link if anyone else is looking for it... http://www.mil-specproducts.com/productPage.aspx?prodID=446 I am guessing that there is not going to be a huge (if any) difference between the Tectyl 846 and the CRC product. |
turboman808 |
Mar 9 2010, 02:59 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Got some exhaust spray from Chris last year that works really good and looks like metal. Wonder how that would work.
Drums66 |
Mar 9 2010, 03:43 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Redline Tranny Juice(no corrosion) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/stirthepot.gif)
Lo-Fi Version | Time is now: 8th May 2024 - 02:13 PM |
