QUOTE(GaroldShaffer @ Apr 29 2025, 12:33 PM)
QUOTE(Ron914 @ Apr 28 2025, 08:03 PM)
QUOTE(Steve @ Apr 28 2025, 09:34 AM)
QUOTE(TheCabinetmaker @ Apr 27 2025, 03:06 PM)
I have a few, but don't know if they work and not sure how to check when out of the car
You can jury rig an electric drill to turn it.
You will need an old speedometer cable to attach to the drill if out of the car .
Actually just the trip rest cable. One end will fit where the speedometer cable goes and use the other end in the drill. Make sure you run the drill in reverse.
When I was testing my original speedometer I think I might have run it in reverse (not knowing any better) After I replaced my cable I noticed the odometer no longer worked and the speedometer didn't quite seem to be accurate . Did I mess my original one up by doing this .
@GaroldShaffer Would you happen to have a trip reset cable because I seem to have misplaced mine ?
