Full Version: Fuel Injection head temp extension In stock!
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
Pages: 1, 2
914ltd
I first used these while working at a Porsche dealership in the early 70's. I believe we purchased them from a VW dealer.
This little device slows down the heat getting to the head temp sensor and after initial warm up, it has no effect on running. $30. with 2 copper seal rings. Post included
Does not include the head temp sensor.
Quinn Moore
I'll take it. PM sent. Thx.
914ltd
More available. $30. with post
QUOTE(914ltd @ Mar 1 2024, 08:47 PM) *
It seems (?) that this might make the CHT sensor easier/faster to replace (if the extension stays in place)?
What’s the likelihood that removing the CHT unscrews the extension, too?
Interesting potential.
yellowporky
I will take one.
Thanks
FlacaProductions
I'm in.
Sending PM.
Van B
Yes, please. I’d like one.
Rob914
Hi Brad,
If I can mail a check, I'll take one, too.
914ltd
QUOTE(StarBear @ Mar 2 2024, 05:54 AM) *
Hopefully you won't need to remove the CHT often.
It's probably about 50/50 that it would stay in the head unless you use Locktite. A small dab of anti seize on the CHT itself would also help.
Keep in mind you are installing a steel threaded part into the much softer aluminum cylinder head. The threads can strip out easily. Brad
yellowporky
Brad,
I never received a response to my pm. Can you send payment info please
Thank you,
Chris
Rob914
Chris,
I ordered one from the 914 Limited website.
FlacaProductions
@yellowporky - same here but I know he's been having some health concerns so I think I'll just let it ride. I know they're available on his website and also through his ebay store if you're in real need. Same price.
yellowporky
Thank you guys for the heads up
s13u74cr4
Ordered one from 914 LTD awhile back after reading COUNTLESS posts on rough idle on a 73 and taming it. Made a noticeable improvement instantly for the warming up cycle.
DRPHIL914
@914ltd
Brad,
if you have another available i am interested,
Phil
BeemerSteve
Hello Brad,
I'd be interested in one as well. Do I PM you to order?
FlacaProductions
Greetings All,
No update on my end but I'm sure there is something legit that's keeping Brad from responding to this thread. I hope all is well.
Meantime, I just ordered one of these (same price) from the 914 Ltd. store on Ebay. Got a confirmation of shipping the next day.
https://www.ebay.com/itm/276152579819?mkcid...&media=COPY
914ltd
I hope everybody has been answered. My energy and days have been short. My memory ain't too good either! Please contact me by my Email or leave a message. Thanks, Brad
914 Limited Inc.
Brad Mayeur
1162 N. Byerly Hills Dr.
East Peoria, IL. 61611
309-694-1797
P914LTD@yahoo.com
FlacaProductions
Hey Brad!
I got one thru your ebay page so i'm good to go - thanks!
b
914ltd
914ltd
Big improvement in cold start running and driving issues. Brad
914ltd
914ltd
914ltd
Great device for initial rough running.
jim_hoyland
Can I still place an order ?
Jom
FlacaProductions
@jim_hoyland - you can order direct here. Same part from Brad.
https://www.ebay.com/itm/276714473501?mkcid...&media=COPY
jim_hoyland
Thanks for the link; ordered one via eBay
QUOTE(FlacaProductions @ Nov 11 2024, 05:09 PM) *
914ltd
DC_neun_vierzehn
QUOTE(914ltd @ Mar 2 2024, 02:08 PM) *
@914ltd I bought one of these from you a while back, but have not installed yet. I'm looking for guidance on installing the extension for someone who's never installed a CHT nor an extension.
1. Obviously, I don't want to strip the cylinder head. Is there a torque LB you recommend for the extension into the head ... hand tighten only?
2. Same question for the CHT on the extension - what torque should I use?
3. Lastly, should I install the CHT on the extension first, then install the extension into the CH?
Thanks in advance.
914ltd
QUOTE(DC_neun_vierzehn @ Nov 16 2024, 12:15 PM) *
Thanks in advance.
You would want firm contact with the copper (or aluminum) washers for good heat conduction. There is no published torque but I would think 10 LB would be sufficient. Read the above post for more information. Brad
914ltd
914ltd
914ltd
Available
914ltd
QUOTE(914ltd @ Feb 17 2024, 01:07 PM) *
In stock ready to ship.
914ltd
914ltd
914ltd
Warm weather is coming. How does your 914 drive in the first mile?
914ltd
L-Jet914
QUOTE(StarBear @ Mar 2 2024, 06:54 AM) *
Do you think this would be viable on our 1.8s vs the D-Jet cars? I am probably going to replace my CHT sensor with one that I got from Jeff Bowlsby as the insulation on mine is coming off. I will be purchasing the correct socket to remove a wired sensor.
914ltd
QUOTE(L-Jet914 @ Mar 9 2025, 09:35 PM) *
Enriching the mixture when engine is cold would be the same for the Ljet and Djet. It might be helpful to prevent damaging lean backfire common to the 1.8. Brad
Sea Rooster
Hi Brad,
Just ordered one from the 914 Ltd website. After I ordered I noticed you had closed up shop.
Can you still fulfill the order?
914ltd
Yes, I am selling my collection of parts and 914 items I have offered previously. I am no longer servicing 914's. After 50 years, my body wore out but I'm still happy to work with the enthusiasts that helped me all these years. Brad
Sea Rooster
QUOTE(914ltd @ Mar 11 2025, 07:43 PM) *
Great! Look forward to getting the part!
Sea Rooster
914ltd
Available
914ltd
Very popular item. Works very well on "lean cold running"
Ron914
QUOTE(914ltd @ Apr 25 2025, 09:21 AM) *
Hi Brad ,
What is the part number on that CHT sensor and price ?
Here is one I purchased already ,is yours the original one?
914ltd
QUOTE(Ron914 @ Apr 25 2025, 07:28 AM) *
Hi Brad ,
Ron, the head temp sensor is not included as noted. Only the extension is offered.
Along with others, 914Rubber.com has the temp sensors. OEM0280130012
They have them listed at $22.50. The OEM would indicate they were Original Equipment Manufacture. Brad
Ron914
QUOTE(914ltd @ Apr 26 2025, 07:11 AM) *
Hi Brad ,
My mistake , I probably wouldn't need the extension here in California since it does not get that cold here .
I believe the sensor I showed a photo of was purchased at 914 Rubber and says OEM-012 type so that's good to know as there is a bit of discussion on the forum about two different ones , one is recommended the other is not .
Thanks
914ltd
Invision Power Board © 2001-2026 Invision Power Services, Inc.
