QUOTE(914Sixer @ Oct 12 2022, 07:42 AM)
Using D-Jet on with MPS tuned by Jeff B. Engine is 2056 with Elgin cam with slightly more lift and Hoffman heads.
QUOTE(ClayPerrine @ Oct 13 2022, 03:40 PM)
QUOTE(r_towle @ Oct 12 2022, 07:17 PM)
You do not need a larger throttle body all the way up to 2.4 on djet.
Tuned on a dyno
Fact
If it is a 1.7L D-Jet, you need a bigger throttle body. The 1.7L throttle body is a little bitty bugger.
If it is a 2.0L D-Jet, you don't necessarily need a bigger throttle body, but it can make it a bit more peppy.
i have a similar set up , 2.1 9.5compression, d-jet, and i installed this summer a 49.5mm throttle body, bored out stock '73 2.0 TB from Chris Foley, I can tell you it does make a difference from mid to high end for sure . With the modified cam, conter balanced crank and new heads with larger valves ported and polished, it all makes a difference so with these other changes, more air coming in helps on that top end where it felt before like it was not getting enough. Id like to do a before/after dyno but i dont have that ability. Seat of the pants evaluation says it does.
