QUOTE(r_towle @ May 18 2022, 11:28 PM)
Please post your experience if you do this
Tangerine's? I have them on both engines, street and race.
I like them for a few reasons:
- They're not the cheap thin Coke can aluminum tubes that seem to be popular now. They're made of sturdy Stainless.
- I'm guessing they're slightly larger diameter with machined grooves for Viton o-rings. When you slide them in you get a satisfying solid "thunk" so you know they are seated very well. I use a little engine oil on the o-rings as assembly lube.
- Uses a smaller diameter tube where it gets close to the exhaust stub in a couple places, better clearance for my Tangerine headers.
- Chris has welded a flange around each one, making removal easier. No more clamping Vice-Grips (or whatever) around the tube, simply lever against that flange to pop them out.
- Available in custom size, though I did not need it, even when I needed shorter pushrod tubes.
- And most importantly: no leaks.
