Jan 14 2022, 02:32 PM
So i purchased the 914 Rubber manual throttle control for the 6 thinking it would be nice to warm up before a track session without minding it personally. However my car has the rennline shifter and therefore no provision for mounting it. Has anyone modded their redline shifter to keep the throttle lever?
Jan 14 2022, 02:58 PM
I believe 914forme milled a slot in his for the throttle lever. It shouldn’t be hard to just duplicate the factory shifter.
Luke M
Jan 14 2022, 03:14 PM
QUOTE(BillJ @ Jan 14 2022, 01:32 PM)
Are talking about a RennShift Shifter ? Not sure what a redline shifter is.
If it's a RennShift unit then yeah I had one modified to fit a factory 914-6 throttle lever.
Jan 14 2022, 03:19 PM
Is there an "easy" way to add a hand throttle to a 2.0 with twin Webers?
Luke M
Jan 14 2022, 03:28 PM
QUOTE(930cabman @ Jan 14 2022, 02:19 PM)
Look here :
https://914rubber.com/manual-throttle-actuator-kit-1
Jan 14 2022, 03:34 PM
Yes i mean Rennshift. I bought exactly the kit linked from 914 Ribber.
@Luke M can you share your design?
Jan 14 2022, 03:40 PM
QUOTE(Luke M @ Jan 14 2022, 04:28 PM)
Look here :
https://914rubber.com/manual-throttle-actuator-kit-1Thanks, a bit pricey, but I bet we can cobb something up in the shop
Luke M
Jan 14 2022, 03:48 PM
QUOTE(BillJ @ Jan 14 2022, 02:34 PM)
I had RennShift modify the base to fit my factory 6 throttle handle under their base.
Check the pics out. I would say see if they could do it for you.
RFoulds
Jan 14 2022, 05:50 PM
My J West Rennshifter came with the hand throttle slot. And Bruce Stone sold me the hand throttle pieces.
Jan 15 2022, 07:59 AM
QUOTE(930cabman @ Jan 14 2022, 04:19 PM)
Tangerine sells a hand throttle kit that isn't "correct" but does the job.
Jan 15 2022, 08:56 AM
QUOTE(Luke M @ Jan 14 2022, 04:48 PM)
Looks like a fairly straightforward mod. Will call them monday! Thanks folks.
Jan 15 2022, 11:02 AM
Just saw the tangerine kit. That may be the ticket for me as i dont care about correct really in this case....
JmuRiz
Jan 15 2022, 11:15 AM
I have an early rennshift and the hand throttle on the parts shelf. Good to know they can mill that slot, I might send mine back for the slot (or have a local, with better tools than me, make the slot)
rfinegan
Jan 15 2022, 02:00 PM
Jan 15 2022, 05:47 PM
Get the one from 914 Rubber, it looks like a good replica of the factory set up, which works go
Jan 15 2022, 07:05 PM
Yeah i have it already but i also have the rennshift installed and the car shifts beautifully so i dont want to mess with that. Its not a must on the list for the February race in Savanah so probably back burner for now
