FlacaProductions
May 8 2021, 09:01 AM
First post-Covid vaccine travel and i'm finally getting back to my 914 that's been sitting for 14 months.
The first thing I am going to do is an oil change - should I let gravity help me and do it right away, stone cold since everything should be on the bottom - or should it be warm first?
I"m going to do the tuna can install at the same time so i'll have the bottom of the sump off as well so i should get it all out either way - just wondering.
One vote on the side of doing it warm is that I'd like to take it out for a quick run to see if anything changed (read: eaten by rodents) during the hiatus that would need addressing...then deal with it all at the same time.
I'm sure I'm over-thinking...
Big Len
May 8 2021, 09:49 AM
I would dump what you have in there cold along with the filter and replace with fresh oil/filter. Warm it up to operating temperature, then change it again, this time with the oil being hot.
infraredcalvin
May 8 2021, 10:25 AM
Year old oil? I’d be more concerned about year old gas. Unless the oil is super dirty, I’d pull the coil wire, crank it a few times to get things lubed, then fire her up. Warm it up and then change oil and sump.
FlacaProductions
May 8 2021, 10:39 AM
Yeah - fuel....I did fill it to the top (to avoid condensation loop) and put fuel stabilizer in before I left it - oil is just "due" anyway.
May 8 2021, 10:41 AM
If the oil doesn't have a lot of miles on it, I'd probably get it up to operating temp to drain it. That will get more particulates out of the engine
mlindner
May 8 2021, 12:09 PM
Yup, I'm with Perry and Calvin.
