Good evening, If anyone has any leads where I can purchase this connector and pins for the IAT sensor, looks like the same for injector as well. If you can let me know it would be appreciated.
So this is the exact replacement? Were you able to fit it in the housing?
Thanks in advance.
914sgofast2
Aug 13 2020, 07:36 PM
Yes, they worked for me. Those connectors are used throughout the fuel injection wiring harness. You need a special tool or a very small flat bladed screwdriver to release the connector from the plastic covers.
