JMT
Aug 12 2020, 01:28 PM
After installing the 123Distributor and turning the body CCW until the green light turns on this is where the rotor and #1 plug wire line up at TDC. Since the rotor turns clockwise it's already passed the #1 plug wire. Does it have to be pointing exactly at #1 plug or just in the general area to start the engine?
DRPHIL914
Aug 12 2020, 06:47 PM
just in general it should start, but it’s touchy and a very small amount of movement makes a huge difference, so adjust slowly, once warmed up set timing same as usual. should be good to go
Olympic 914
Aug 12 2020, 07:10 PM
Timing is set BTDC (I think 5deg)
Before Top Dead Center
So you should back it up a couple degrees.
Hate to say it but, You are Retarded.....
JMT
Aug 12 2020, 07:27 PM
Lol yes retarded. However, when I back it up to line up with the #1 plug the little green light goes out.
Olympic 914
Aug 12 2020, 07:48 PM
You have to put the 5 deg timing mark in the V ( or 7.5 )
it is before the 0 TDC mark
Depending on your engine and fan there should be timing marks at 27 BTDC, 5 BTDC and 0 TDC.
I think on a 1.8 the marks are at 7.5 BTDC. and 27 BTDC
Someone will correct me if I am wrong.
You could just advance it a little to get it started and then set the timing with a timing light @ 27 btdc 3000 rpm
JMT
Aug 12 2020, 08:06 PM
Hey Olympic. It's a 2.0 so only 0 and 27 BTDC. That's actually what I did to start it but was curious why the rotor and #1 plug don't line up. Maybe it's a moot point since you can customize the curve with the bluetooth app.
Not_A_Six
Aug 12 2020, 08:17 PM
QUOTE(JMT @ Aug 12 2020, 12:28 PM)
You only have to line the LED up good enough for the engine to start. After that, you should rotate the distributor and set the timing with a light at whatever the appropriate advance/rpm is for your engine.
Have fun.
Not_A_Six
Aug 12 2020, 08:33 PM
Is that D-Jet? If so, there are some nuances with the 123. Namely, choosing the right profile from the limited choices available via DIP switch, and getting the orientation/polarity correct for proper fuel injection pulse phasing:
http://www.914world.com/bbs2/index.php?act...=2&t=347291
JMT
Aug 12 2020, 08:46 PM
It's a Bluetooth. I picked a curve that Mcmark suggested to someone on a thread I read here.
Not_A_Six
Aug 12 2020, 08:49 PM
QUOTE(JMT @ Aug 12 2020, 07:46 PM)
Nice! No D-Jet weirdness then. Does the bluetooth version let you set a rev limiter rpm?
JMT
Aug 12 2020, 09:19 PM
It does and just about everything else.
pete000
Aug 12 2020, 10:12 PM
When I did my 1.8 i just started where the green light was on then set the timing using the flywheel marks. These are great distributers. The blue tooh adjust ability is fantastic.
