They are interchangeable.
The seals have to be cut for the car they are installed on, but they are the same profiles. So if cut to fit on another car, I would not expect them to fit your car precisely.
Also note that there was an early version of the targa to window seal that doesn’t have a wiper on the outside edge. Factory superseded this part to the one that seals better for a reason. We saw no need to duplicate an inferior seal.
You can see how this is an improvement by creating a 2nd barrier for water.
It just needs to be adjusted properly for your car.
If you really wanted the old profile you could carefully cut off the lip
Note this is shown with the front main targa seal not installed. It would normally but up against this end
