Full Version: How to remove dash components.....
BuddyV
What's the best way to remove the housing for the dash accessories?
AKA, the part of the cigar lighter that is set into the dash.
i would rather NOT remove the entire dash. Hoping someone can decribe a simple method.
Thank you.
iankarr
Disconnect battery. Reach up behind the dash. For the lighter, spin off piece that holds it tight against the dash.
For the headlight, fog and hazard switches, first spin off the knob (counter clockwise), then remove the flat escutcheon "nut". You may need a special tool like this...
https://www.mtmfg.com/part/view/escutcheon-...ASABEgJKgvD_BwE
(not sure if this is the correct tool, but it looks like this. Mine has no markings on it.)
The cigar lighter is different from the other switches and is a bit of a PITA. The housing slides through the dash from the front and then a round spring retainer slides on from the backside to hold it in place. It's easy to install but kind of a pain to remove. I use a plastic body panel pry tool to wedge between the back side of the dash face and the spring retain and wiggle it back and forth, working around the retainer as best you can, to work it off. Here's a pic of the parts.
IPB Image
BuddyV
YOU GUYS ROCK!!!
I can take it from here. I really helps to get an explanation of what is on the back side.
Cheers!
barefoot
My lighter socket was different from the one pictured, it had a spin on NUT that was easy to remove.
I made my own tool to remove the switches by slotting a nickel with a hack saw.
sjhenry1075
QUOTE(barefoot @ Feb 24 2020, 07:47 AM) *
"slotting a nickel with a hack saw".. That's some serious ingenuity..
aturboman
Early lighters were retained by a spring ring (picture above) which is a PITA to remove. The later cars (1974-) from my experience had a large nut like retainer with a compression spring holding them in which made it much easier to remove and install.
QUOTE(barefoot @ Feb 24 2020, 04:47 AM) *
I used a pair of needle-nose pliers for the "escutcheon". Open them up partway so the tips of the pliers fit in the slots or holes (I think there were some with holes instead?) and spin it off.
The cigarette lighter is one of the most annoying disassemblys on the car.
