Oct 12 2019, 09:49 PM
I would appreciate some answers and other feedback--don't be shy.
A month ago I brought home a 1973 2 liter. The car came with a COA that shows the engine and trans as original, as is the color. It has all the original performance/appearance parts, including 5 good Fuchs wheels. It was not running when I bought it, but did run earlier in the year. My initial assessment showed some minor rust and body issues, but it looked solid.
Now after a month of stripping down, I have found more rust, mostly in the floor. The areas under both seats are either very thin or with some small holes, and both front floor corners have 4 inch holes. The upper fire wall behind the passenger seat has rusted through, as has the right engine shelf. The top of the hell hole has extreme scale, but no holes (until I really dug in with my chisel). And I found a couple of small holes in the inner fender where the battery tray (replaced) attaches. On the plus side, the longs are very solid and clean, inner and outer, on both sides, as is the lower fire wall where all the cable fittings attach.
Other body issues: the front and rear right fenders were replaced at some time, as was the right side of the front panel (but the floor and inner right fender are original). The groove for the front trunk gasket is messed up in places, but not rusty. The rear trunk and engine lid hinge mounts are messed up.
The windshield was glued and sealed with at least 4 different kinds of stuff. All the bright trim, and the bumpers, were painted black--and the front bumper looks repaired under the paint. And the black carries over with undercoat sprayed in the engine compartment, both trunks, and passenger area.
Inside, the seats were recovered--not stock but look pretty good. The dash and firewall cover look good. The door cards are uncut, but somebody cut speakers into the sides of the center console.
One final observation: the more I take things apart, the more ghetto repairs I find, with non-stock, mixed hardware, home-made brackets and wiring, and cheats.
First question: should I continue with my plan to restore to a nice running but not 100% vintage state? I kept looking for a place to stop as things came apart, but in my quest to remove all the sketchy stuff I am approaching a bare shell.
Second question: is this car worth the effort to replace the floor, patch the other rust, and straighten various bends and mis-fits? I know I will end up with a complete paint job, and replacing most of the rubber and trim. And none of this even considers the drive train.
Final question: if I end up with the body shell stripped bare, what's the logical approach and order of work, considering the floor, local patching around the hell hole and fire wall, and work on the front and rear?
Oct 13 2019, 04:58 AM
Welcome to the world of 914s and the crap previous owners did to these cars when they literally cost more to keep running than they were worth.
I'm going to go out on a limb based on your garage space and say you have the space, tools and resources to fix it. So just dig in and fix it.
There are very few cars out there that don't have skeletons in the closet.
When you are done you have a reliable, known car.
The other option is go buy a $25k California car and hope for a better starting point. But, it will have skeletons too! There have been many $50k cars that still have skeletons. Typically as you move up in price point the concern items get smaller but there are still details that need work. Your call on where to start.
In my case I started with a rust mobile because I'm in the Midwest and don't mind metal fab work but I do value having a known commodity when I'm done. There are days I question my strategy but I really value having things done right.
Many of the issues that you'll see on this site are the result of 1/2 ass fixes. Old wiring needs to be taken care of. Drive trains need complete rebuilds, etc. If you take the time to fix it right, it will last another 45 years with good reliability. If you duct tape and bailing wire it, it will be unreliable for anything more than short drives between problems.
jimkelly
Oct 13 2019, 05:39 AM
this is going to be a restoration to watch
please please please, post a lot of pics
have you settled on a budget for this build?
rebuild engine(mcmark), trans(dr evil), suspension(pmb), brakes(pmb), all new rubber(914rubber), wheels, peddle cluster, guages, misc (bdstone914), etc etc
idk, strip everything, fix, paint, buy lots of parts, assemble ??
cassmcentee
Oct 13 2019, 05:59 AM
Thanks for posting this!
I'm in the same boat with you...
You just described my exact situation. (though I might have more floorpan rust)
I'm currently rebuilding the drivetrain motor/trans figuring that is the most INSPIRATIONAL place to start.
Constantly perusing the forum for information that will be needed as i progress.
Good Luck and Cheers!
Cass
Oct 13 2019, 06:18 AM
Some of the best looking cars are bondo queens under the paint. So at least you know what you have. If you have the skill and patience, work the repairs, one at a time, until you have a solid chassis but remember, perfection is the enemy of good. These cars are great drivers so don't get so caught up that you don't get it back on the road and have some fun.
SirAndy
Oct 13 2019, 10:56 AM
QUOTE(Superhawk996 @ Oct 13 2019, 03:58 AM)
... based on your garage space and say you have the space, tools and resources to fix it. So just dig in and fix it ...
914_7T3
Oct 13 2019, 11:14 AM
Fix it! Not too many '73 2.0 matching numbers survivors out there. As long as you have the time and resources to do the job, go for it!
Here is my story of going down the slippery slope
http://www.914world.com/bbs2/index.php?showtopic=308753
Oct 13 2019, 11:19 AM
QUOTE(SirAndy @ Oct 13 2019, 10:56 AM)
+1 If you like doing this kind of work and have the ability, then yes, it is worth it. Parts and materials to repair the metal are not that expensive, it is the labor costs that put these projects upside down.
The only part of your description that causes me worry is that the right fenders were replaced. Makes me wonder if it was in an accident, so I would at least take lots of measurements to make sure it is straight. Everything else sounds pretty standard.
I don't think I've ever seen or heard of a 914 COA that verifies the transmission. Most just come back with 'Information Not Available' or something like that. Interesting to hear that information DOES exist.
rjames
Oct 13 2019, 12:19 PM
Agree with Brent. Make sure the tub is straight before going any further.
Oct 13 2019, 12:26 PM
I'd say measure it to know what hidden body repairs await you besides those you know of. Andy has those measurements and points posted somewhere here. Maybe "914 Info"? If those are good enough for you, the pans nor that upper area behind the psg seat are that difficult. Those 4" holes in the front that you mention; is there one on each side and about 4" in diameter? Measure that trunk hinge location about 6 times.
I got mine about 1/4" off and need to resolve that next time the engine is out. Back to your 914..............If later you find the shell isn't worth the effort you've pulled the good stuff and can easily transition to another shell or sell the parts.
Oct 13 2019, 12:31 PM
QUOTE(76-914 @ Oct 13 2019, 12:26 PM)
Yep. '914 Info' link in the upper right corner of this page.
iankarr
Oct 13 2019, 05:59 PM
QUOTE(mepstein @ Oct 13 2019, 08:18 AM)
The more concours/perfect you want the car to be, the longer and more expensive the restoration. It's easy to slide down the slippery slope of perfection, so what I like to do is set either time or money deadlines (or both). Then work backwards to keep the car on track and on budget. If you don't do that, you'll be saying "might as well" a whole lot...and the car is just about guaranteed to stay off the road indefinitely. And when it does get back on the road, you'll either be reluctant to drive it...ot love driving it so much that it quickly won't be "perfect" anymore.
As for what to do first, I'd remove the glass and tackle the structural and body to prep for paint. Then while the car is in paint, work on the engine. When the car comes back from paint, install the wire harness, steering components, airbox and controls, fuel tank and lines, front and rear suspension, wheels and brakes. Then put the engine in (or if you have room, keep it out till the very end.). Then do the interior, starting with the dash top (which requires the glass to be out). Put the glass in when the interior is complete, then connect everything up and drive. No big deal...you'll have it done in a weekend
As others have said, you seem to have all the raw materials, and by the questions you're asking, this doesn't seem to be your first rodeo. Definitely go for it!
type2man
Oct 13 2019, 06:24 PM
My own opinion, and this after years of restoring cars, just buy a really nice 914 unless youre in your 20's and have plenty of time to tinker.
Yes, you wont be able to tell everyone at the car show that you built it yourself but the reality is, you might not have the talent it takes to lay the paint, upholster the seats, and rebuild the engine, so bottom line when youre at a show, you have to confess that someone else did half the work and you just assembled it.
Why spend 3 years building a car and spending countless nights suffering in the garage (unless thats your thing) I'd rather spend 3 years driving something that someone else restored and is selling for a loss. And even then, you can still tinker with a perfect car on the weekends personalizing it. My 2 cents
DickSteinkamp
Oct 13 2019, 06:47 PM
If you are a competent mig welder, consider it. But even then, make a CONSERVATIVE budget. You will be upside down in this car no matter what (not necessarily a bad thing). A detailed budget will give you an idea of how much. You can then decide if it is worth it.
Oct 13 2019, 08:16 PM
Thanks, everyone--I much appreciate your replies. Some answers (and more questions).
I do have the space, tools, and experience, though the last true restoration I did was 20 years ago. And I sort of have the time, since I am semi-retired with lots of flexibility in my schedule.
I understand and agree about how almost all older cars have hidden surprises, and fixing something correctly is a good way to know what I have.
I don't have a budget (yet), but I have thought about how far upside down I can tolerate (with an alternate view below). Let's say I finish this by stripping, fixing, and painting the body, rebuild the engine and most mechanicals, install the original decent interior, and restore or replace all the trim and rubber. This would not be a concours product (I hope I can resist trying for that). What would a fair value be?
I worry about finding replacement fenders front and rear on the right, but the door looks untouched (and original), as do the front and rear interior panels. My guess is that the car got dinged mildly on both corners, maybe in separate incidents. I do plan to measure as much as I can and check the alignment before going much further.
After talking with my son today (and all the feedback so far from 914World) if feel encouraged. My son asked the key question: is this what I want to do with my time? Right now, I say yes. And I am willing to pay not just for the result, but for the "fun times" ahead.
DickSteinkamp
Oct 13 2019, 08:26 PM
Hagerty values a "Good" one at $20k. Their description of "Good" sounds like what you might end up with.
BaT has sold 120 914s. Looks like they are clustered in the $15-20k range. Find some of the most recent sales there that closely match what you will end up with.
type2man
Oct 13 2019, 08:47 PM
If you want to tackle it, I would find a super nice shell to start with, should be easy to find under 5k.
raynekat
Oct 13 2019, 11:11 PM
Looks like you've got quite a project on your hands there.
Good luck.
Oct 14 2019, 08:18 AM
you are into it this far and your labor is free, so why not?
BuddyV
Oct 14 2019, 06:19 PM
Cut your losses.... sell it to someone looking to build a race car..... look for a driver-quality car and DRIVE IT!!!!!
TargaToy
Oct 15 2019, 10:08 AM
...but remember, perfection is the enemy of good. These cars are great drivers so don't get so caught up that you don't get it back on the road and have some fun.
My gosh, Mark. I've been mulling this quote of yours over and over ever since I read it. What an excellent piece of wisdom. This quest for perfection has kept me stunted on my own build way longer than it should have. It's actually a bit liberating to put things back in perspective and realize that a GOOD car, with some flaws and grime, will be way better and more fun than a car on jack stands moving glacially towards some end goal of a full or perfect resto.
Thanks, man!
RMGaiss
Oct 15 2019, 01:20 PM
Based on what I've seen, I'd say go for it. Your time and labor are your own, and you'll have the satisfaction of having done it yourself. There is a lot of good information on this forum. And there's You-tube. You can learn a lot watching other people do stuff. Just my opinion.
Olympic 914
Oct 15 2019, 06:42 PM
Also in the "just do it" camp.
My restoration took over three years. the money spent was spread over that time. I am probably upside down on it, but I didn't build it for the next guy. or to sell.
Its not perfect, but its damn nice. and there will probably always be something else I may want to do, or change. That's part of the fun.
And I love driving it.
You will learn a lot by doing it yourself. There is pride in saying you did it yourself. If you just wanted to drive one you wouldn't have bought this one anyways. and I see another Porsche in your garage. Drive it while you work on this one.
Don't be afraid to ask questions, This group is very helpful. and many of us have done it wrong once also.
Good Luck.
Oct 15 2019, 08:31 PM
Again, thanks everyone. I appreciate the comments and encouragement.
I did go through all the measurements I could, and the car is very straight and square. And where I am confident I measured the exact dimension, the car matches the specs within a 1/16 inch (except for the rear trunk length measurement, but the back panel is visibly pushed in a bit).
The shell is now completely stripped, except for suspension and steering. I have a line on a rotisserie, and if that works out, I will get the shell mounted before starting some paint stripping and rust repair. (And the doors will come off, once I fab some braces.)
Oct 15 2019, 08:34 PM
One more fun surprise: when pulling the fuel evap hoses, I found a fair amount of oil in one.
iankarr
Oct 15 2019, 08:43 PM
QUOTE(bkrantz @ Oct 15 2019, 10:31 PM)
The back panel was pushed in a bit on one of my cars as well. Seems like a common result from a low speed rear hit since the bumpers really didn't...bump. Mine needed to be pulled on a bench. Def recommend getting everything straightened before going too deep. Otherwise, have at it!
Oct 15 2019, 09:24 PM
QUOTE(bkrantz @ Oct 15 2019, 08:34 PM)
I wonder if someone mistakenly hooked up the evap hose to the oil breather. That's gross!
Also, I'll pass along the same great advice I got when I started my project. Brace the door openings before starting any rust repair and get all the repairs on the structural members done before putting it on the rotisserie. It's best to repair longs and hell hole with the car level and well supported. It doesn't sound like you have any major structural issues to repair, but make sure before hanging it on a rotisserie.
I'm excited to watch this build!
Oct 16 2019, 05:00 AM
Oct 16 2019, 08:37 PM
Thanks--that's my plan.
Now to start a rebuild thread.
Oct 16 2019, 08:51 PM
QUOTE(cuddy_k @ Oct 15 2019, 07:43 PM)
The rear trunk would not open on the '70 model I purchased in 2017. In it were various parts shipped with car by seller. I was like
How did that latch fail between NC & CA. I discovered that the rear panel was pushed in maybe 1/2" which resulted in the lock mechanism not making contact when rotated.
The car was not running when purchased and needed to be loaded by hand. I'm sure someone pressed in the rear panel when it was loaded. After removing the lid via the "long multiple 3/8" extensions" I was able to gently pull that panel 1/2" rearward with just my hands with very little effort. That area does not resist inward pressure.
horizontally-opposed
Oct 16 2019, 09:00 PM
Nice to see you over here, and it's hard to beat a matching numbers 1973 914 2.0 when it comes to the four-cylinder cars. If that car measures out right, it sure looks like it's worth saving to me. I'd target getting the body really right, and then putting it back together with most of the same parts it came with as a "nice driver"—you can always chip away at various parts of the car as a fun project over the years to come so long as the basic chassis and paint are right.
And a 914 is a VERY enjoyable car to drive and work on in small chunks. It's usually the bodywork and then "need" to make everything else as nice that keeps good cars off the road for years. Ask me how I know…
