QUOTE(brcacti @ Oct 8 2019, 06:04 PM)
Steve L. ................help, not BS please, I just got this car and am not a mechanic, easy to answer for some, is that all you have to offer is BS?
They are black round relays close to the motors / headlight buckets. I would swap them and see if they switch which one is working.
If not a relay could be wiring - headlight switch -
You have to be really really careful - those motors / mechanism can take a finger off
You can manually raise and lower with the little black knob on top of the motor.
If I remember correctly if you leave the relay in and slightly turn the knob on the motor it will operate up and down. (Could be wrong there)
