Backpad light, Is a correct light available? |
robkammer |
May 18 2022, 03:04 PM
Member Group: Members Posts: 179 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Hey Teeners! Getting close to finishing up the BB interior, electrical issues are resolved and carpet is almost in. When the car came to me the backpad light was inoperable and missing. That circuit was also dead. Got the wiring right and ordered a new reproduction light. (the second one tested OK.) Went to install it and find that the backpad is much thicker than the new light is designed to clip to. I've included a picture of the metal tangs on the back side of the pad, they are a good 1/4" from the vinyl on the front.
The backpad looks to be original, it's had some repairs to the masonite but the vinyl appears to be original. Any input would be appreciated. Rob |
StarBear |
May 18 2022, 03:11 PM
Senior Member Group: Members Posts: 1,849 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
It’s been a while since I’ve looked but don’t recall having that metal backing. Mine (74) just clips onto the fiberboard, I think. (IMG:style_emoticons/default/confused24.gif)
rgolia |
May 18 2022, 03:33 PM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
I think the metal backing is stock. I suggest an LED bulb so the plastic doesn't melt like many have if the light is left on too long.
Steve |
May 18 2022, 04:58 PM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have not seen an original repro with the white button and chrome surround. Used ones are ridiculously expensive. Aftermarket with black button and no chrome surrounds work, but I had to wrap double sided tape around it, to keep it from falling out. I also switched to an LED bulb available at Walmart and other places to stop it from melting.
wonkipop |
May 19 2022, 02:58 AM
Advanced Member Group: Members Posts: 4,243 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
exact same light is in a 70s beetle beyond a certain date.
its a junkyard job if you want to find an original one. go look for beetles. good luck. otherwise get the repro with the black switch. @StarBear is right i believe. its been a while since i was in the back of mine but that backpad has been repaired i think. probably fibreboard let go and got chewed up from replacing melted lights too many times. |
Shivers |
May 19 2022, 07:07 AM
Senior Member Group: Members Posts: 2,345 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
This was not posted in originality...I've seen this done a few times, I thought it was a nice answer. http://www.914world.com/bbs2/index.php?showtopic=315994
Literati914 |
May 19 2022, 09:16 AM
Senior Member Group: Members Posts: 1,436 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Just a note to say that the metal strips at the side (of the light opening) ARE original. I recently made and added a set of them to a new 914rubber backpad molding/frame, based on the two original pads that I had on hand, having them. I had to create and add the metal tabs too for keeping the whole thing to the firewall (but that’s another story)..Here’s the tabs for the light:
Attached thumbnail(s) |
jrmdir |
May 19 2022, 10:32 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Will this fit? Looks pretty close to the original 914 version. Except for the Hella lens pattern.
https://www.jbugs.com/product/211947111BC.html |
burton73 |
May 19 2022, 10:43 AM
burton73 Group: Members Posts: 3,493 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I Would totally go with the $20. Light from JBugs.
If the size is not perfect, make it fit Bob B |
May 19 2022, 11:43 AM
I think the metal backing is stock. I suggest an LED bulb so the plastic doesn't melt like many have if the light is left on too long. (IMG:style_emoticons/default/agree.gif) |
wonkipop |
May 19 2022, 03:19 PM
Will this fit? Looks pretty close to the original 914 version. Except for the Hella lens pattern. https://www.jbugs.com/product/211947111BC.html that bus light is much bigger than the smaller beetle light that was fitted to 914s. |
Sprout |
May 19 2022, 04:35 PM
Member Group: Members Posts: 125 Joined: 5-October 18 From: Kansas City Member No.: 22,544 Region Association: Upper MidWest |
I would not buy the JBugs Beetle light. I did, and it did not have the right-angled tabs along the bottom. They stuck straight out so hit the backboard before the light snapped in place. I tried to bend the tabs but one broke. I ordered one from Stoddard and the tabs were correctly bent as shown in the OP's pic. I think it was $25 at the time.
wonkipop |
May 19 2022, 05:28 PM
attached my original that came with car.
it broke 30 years ago. about 2 years ago i kind of repaired it as best i could to have as a desperation spare. you can see in the photos the problem in a nutshell. originals have a tab positioned on one side which is set sufficient depth to key with the backpad. same goes with the metal spring clip and the positioning of the bent indent. back 30 years ago i figured out the replacement black switch lights that superceded the original types (fitted to golfs) did not fit well - the indents and spring clip were not the same. i went to a VW wrecker in my city with my broken 914 one - he took one look at it and said it was a beetle light. i managed to get 2 out of him. the light was in beetles from about 1970 on. that was a quarter of a century ago. if you could find a VW wrecker who still has stuff on their shelves you would probably manage to get one. problem with the typical ones sold now by porsche/vw aftermarket shops is 1) the restraining tabs and spring are not sufficiently distanced. 2) the construction and castings are cheap and prone to breakage. its a bit of a problem. i did poke around in the back of a 1990s VW transporter that was in the workshop where i recommissioned my 914 a couple of years ago. found these. they are not original in appearance but are well made german hella lights. exactly the right size and do the three switch position thing. i've got one as a back up in my box of spares since the bug lights i do have are incredibly frail at this point in time. i've got one of those bug lights in the car and one for back up and the original one i repaired. each time you take one out you hold your breath removing it. here is one of the bug lights i got 30 years ago. still in car. same part as fitted originally to 914s. really early 914s might have had the earlier bug light which did not have a flush switch but had a kind of domed switch. but this is the right one for later 914s. so if you go on the search and find a good VW wrecker you might turn one up. |
Literati914 |
May 19 2022, 08:14 PM
robkammer |
May 20 2022, 04:01 AM
Thanks guys. All good information. I should have gone to Stoddard first. I'll call them later today.
Montreal914 |
May 20 2022, 09:39 AM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
StarBear |
May 20 2022, 10:58 AM
A few have mentioned an LED bulb to replace the standard one. What is the designation number/code for the correct one?
Root_Werks |
May 20 2022, 12:26 PM
Village Idiot Group: Members Posts: 8,305 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The light in my 914 is a rocker type. Centered is switch activated, tilted one way is always off, another, always on.
Not original 914? Small, bad picture, was of the whole windshield out: Attached image(s) |
burton73 |
May 20 2022, 12:32 PM
In my 6 #41 @ PMB ---- 911 part real metal, just a touch wider you can do it and it looks great IMHO Bob B |
Root_Werks |
May 20 2022, 02:04 PM
Ah ha! Thanks @burton73 that explains things. It was already in the backpad, the PO must have installed it.
Lo-Fi Version | Time is now: 25th April 2024 - 02:55 AM |
