WTB: 71 Aux Air Regulator |
Shackleford |
Jan 14 2022, 01:11 PM
Newbie Group: Members Posts: 35 Joined: 9-August 21 From: Ca Member No.: 25,788 Region Association: None |
Does anyone have a functioning AAR? Mine seems to be electronically bad. Not just stuck. When hooked up to power something seems to draw allot of power and my bench top power supply goes into protect mode and turns off the power. Not sure why. it measures 15 ohms of resistance. Afraid to hook it back up cause I don't want to dry a relay or a fuse.
Looking for a functioning one. Thanks! |
JamesM |
Jan 14 2022, 07:25 PM
Senior Member Group: Members Posts: 1,872 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It draws a lot of power because its basically a short to ground with a bit of resistance in it. The power draw is what heats it up causing it to close the valve over time.
15 ohms is normal If the heater is working (which is sounds like it is) the only other mode of failure is the valve getting physically jammed from moving. If this is the case, soak the hose end in PBblaster or other penetrating oil overnight to free it up. Its a very simple device. |
JamesM |
Jan 14 2022, 07:26 PM
Shackleford |
Jan 15 2022, 12:16 PM
It draws a lot of power because its basically a short to ground with a bit of resistance in it. The power draw is what heats it up causing it to close the valve over time. 15 ohms is normal If the heater is working (which is sounds like it is) the only other mode of failure is the valve getting physically jammed from moving. If this is the case, soak the hose end in PBblaster or other penetrating oil overnight to free it up. Its a very simple device. Thanks! Guess I’ll just see if I unstuck it by installing it. I had soaked it in PB blaster for a few days. |
StarBear |
Jan 15 2022, 02:10 PM
Senior Member Group: Members Posts: 1,829 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Lo-Fi Version | Time is now: 28th March 2024 - 08:14 AM |
