HOT IN VEGAS !, Front oil cooler line |
DMAYHALL |
Feb 24 2021, 04:16 PM
Newbie Group: Members Posts: 13 Joined: 26-June 14 From: las vegas Member No.: 17,557 Region Association: None |
Out here in Vegas its Hot ! so I am installing a front oil cooler and was wondering has anyone ever routed the lines through the heater tubes in the longs ? i do not have exchangers so they tubes seem like they would be perfect ?? i will be running the lines down the passenger side just for easy access to the sandwich plate. let me know what you guys think ?
Robarabian |
Feb 24 2021, 04:24 PM
914 A Roo Group: Members Posts: 590 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Out here in Vegas its Hot ! so I am installing a front oil cooler and was wondering has anyone ever routed the lines through the heater tubes in the longs ? i do not have exchangers so they tubes seem like they would be perfect ?? i will be running the lines down the passenger side just for easy access to the sandwich plate. let me know what you guys think ? I have a Renagade Subaru conversion. My cooling lines run through the tunnel. When I recently installed an water to air intercooler, we ran the lines through the heater tubes and out the back. Worked great. |
Chris914n6 |
Feb 24 2021, 11:07 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Most of the oil lines I've seen are braided and braided will eat sheet metal. Plus braided doesn't bend tight. Plus it's pricey.
I did see a swap that had an oil/water heat exchanger. So the oil stayed in the engine bay and less was needed. The water ran up front to a small radiator with a fan. I've seen enough catastrophic oil hose failures that this made sense. I'd do all 5/8" and use a Bosch heater pump and a large heater core. |
mate914 |
Feb 25 2021, 08:02 AM
Matt Group: Members Posts: 730 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
A lot if people do this run up the heater tubes...
Matt |
Feb 25 2021, 08:16 AM
Life's been good to me so far..... Group: Admin Posts: 15,392 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I had a thought..... (IMG:style_emoticons/default/idea.gif)
Run finned oil lines up the heater tubes, and put the oil thermostat at the front of the car. Then put a blower at the rear of the heater tube, and blow air over the finned lines to generate heat for the interior. In essence, make the heater tubes one long heater core. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 03:59 AM |
